Question about RCA D61W20 61" Rear Projection Television
My rca d61130 projection tv has red/pink faint lines
The lines go horizontally and seem to create a pink hue over the entire screen accept at the top. I can mainly see this with a white background. what part would I need to fix this problem.
  • tanyamo Mar 19, 2008
    I'm having a problem with my RCA d61w20- It has colorful (red, green, blue) wavy horizontal lines going across the screen. I have tried the auto convergence, no difference. It will sometimes just look great upon powering on or after a brief time it will clear upon its own, other than that if i don't see an improvement in over an hour, I just shut it off. Hoping to find a solution.
    Novelist:
    Champion:
  • 211 Answers
It sounds as thought he convergance needs to be adjusted. You will need to push the auto adjust button or go into the menu and do a manuel adjust. Any adjusting instructions should be listed in your Operator Manuel. If you require more assistance in this matter, please write back. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Screen split in half horizontally and duplicated
You didn't supply the make , model of laptop or the OS you are using? Has there been any damage? Dropped? Open Control Panel, Display adapter, Uninstall the Graphics adapter, reboot. Allow the Windows OS to apply the generic driver. post results with info.
Jan 27, 2013 | Computers & Internet
Screen is red with lines when channel is changed
If its a kp-51hw40 : go to an unused video input and look at the screen---if it is redish in the background with curved faint trace lines you have one of two things wrong; First: the red "screen" control may be set too high. Second: you may have a problem with the RED picture tube.
To try to adjust the RED screen down you have to remove the entire front grill plate on the front of the TV(some have screws on the back on either side that have to be removed---and then you should be able to pop it out. Behind it there is a masonite inspection plate held in with screws----Once you have that off look for a SMALL SQUARE BLACK PLASTIC BLOCK; it has 6 black adjustable controls---you have to use a flashlight and look carefully---one row left to right will be marked FOCUS--DON'T TOUCH THOSE---THE OTHER ROW left to right will be marked SCREEN; if you look carefully you will see marked by each r (red) g (Green) b (blue)
you want to locate the RED SCREEN CONTROL.
WITH the set still on a blank video input where you can see it clearly turn the RED Screen Control to the left until the lines and red tint go away---do this slowly and make sure you are adjusting the RED screen--not the FOCUS.
IF this has been helpful give me a vote here as I do this for free; yesterday I adjusted one of these in a home that was blue with the faint lines---about 15 minute job for me.
if you have questions or need help:
etower.766@netzero.net
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Rca 61130 rear projection tv has pink haze
Try adjusting your Red screen control down just a little. This is usually a sign of the red crt developing a short. Often just turning the Red drive down just a bit will make the retrace lines disappear if not you will eventually need a new CRT or repairs in the red drive circuitry. Hope this helps.
Jan 26, 2008 | Televison & Video
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Very fine red lines across srceen
It is an adjustment, but it's an adjustment you may not want to do. It's the red screen control. It's located behind the front panel so the entire front panel has to be removed in order to access it-which will expose you to hazardous voltages. if you like, I can post detailed instructions on how to get that front panel off, it's kinda tricky.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
