Missing hard drive space
I was given an old computer i put an 80 gig hd in it so i reformatted the hard drive and installed os, wiht no full version of wom 98 or win 95 i had ti upgrade . first i installed dos 5.1 then win 3.1 then win 98 upgrade win i started to install win xp upgrade error not enough hd space. so i check hd prop it only showed 2 gigs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Posted on Jan 07, 2008
6ya staff
SOURCE:
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
I keep on receiving error message in my laptop saying my norton 360 has full storage. what should i do?thanks.
Click on My Computer> Right click C: drive (if this is OS drive)
Click "properties" and write down how many megs/gigs are shown as free & available. If your HD was REALLY that full I would expect you'd have considerable difficulties functioning & likely be UNABLE to even do a defrag.
Yes, if you took the deal, you would be paying them yearly, for "extra" storage not on your machine (maybe unavailable should you be unable to access the internet).
You can, for modest money, buy a USB thumb drive of 8 Gigs for about $20 to off load various items (creating more free HD)or do full back up onto a couple of DVDs (assuming you have a DVD burner) or 6+ CDs or to a ext. hard drive used for storage.
Unless there is something new in the program and it will prevent you doing a back up of the machine in normal manor, you don't need to rent space.
Note: I don't use Norton so perhaps I'm missing something
Jan 14, 2011 | Symantec Norton 360 Version 3.0 Full...
Mac OS X 10.4.11 SimpleDrive 1TB HD appears on Desktop only occasionally. Does not appear in Disk Utility. Have transferred files to it, light is on, plugged in, just takes several restarts to appear.
If you unplug the power and USB cables from the drive (but not the computer), plug in the power and then plug in the drive, the Mac will remount the drive on the desktop. I am having the same issue, only my old HDD used to be my TimeMachine drive and now I want my SimpleTech drive for that. The issue is that when the SimpleTech drive disappears, OS X automatically uses my old HDD for TimeMachine and all my disk space vanishes.
Very ARRGH!!!
I'm trying to find a better solution, because having to mess with the cables means it's no good for TimeMachine... and very frustrating on top of it.
Aug 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
175gb missing from 250GB hard drive
Appreciate the "Ask Me".
The only plausible explanation for the missing disk space would be the protected folder "System Volume Info".
Re-formatting would not restore your free space, however, re-partitioning would. May I suggest that you try PowerQuest Partition Magic. Of course like formatting, re-partitioning would completely delete the partition itself and would grant you back the entire disk space.
Unfortunately you can not use the same with the 1st partition since that is your active partition and presumably where your OS is residing. A workaround is to use another hard disk temporarily and transfer all the contents of partition 1 and make that eventually as your primary HD. Thereafter, re-partition again the entire 250Gb HD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Problem maxtor hard drive
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
Nov 26, 2007 | Maxtor Hard Drive
Maxtor 500gb internal hard drive
To fix/restore to full capacity, you may need to delete the existing partition and re-partition then reformat again.
Most old computers have limitations on the CMOS/BIOS as to how big the capacity of the HD that it can recognize.  Windows however would recognize big HD size and therefore can partition, format and check.
Alternately, a third party disk utility program may be used such as Partition Magic.
Hope this be of some use/help. Post back how things turned up or should you need additional information.
Oct 26, 2007 | Maxtor Hard Drive
Hdd
The drive may be damaged physically and is setting the remaining portions of the disc as bad sectors. If this is the case you need to replace your hard drive immediately. If the space is unpartitioned you can do this through windows using a program called partition magic. You can also reformat the drive using a windows cd and it can reformat the drive to 80 gigs (assuming the disc does not have bad sectors).
Aug 06, 2007 | Samsung (SP0822N) 80 GB Hard Drive
How to make Vista to recognize my old Hard drive
There are normally only two ways to get vista to recognise large drives and that is to format it within windows by way of right click my computer then click manage and then highlight your harddrive right click and select format. The other way is if your drive isnt being recognised because of the bios and needs updating, as most bios chips did when upgrading to vista.
Jun 18, 2007 | Microsoft Windows Vista Business DVD...
Computers & Internet Logo
260 people viewed this question
Ekse
Marvin
Marvin
