ASUS P5P800-VM Motherboard
Problem for ASUS P5P800-VM Motherboard
LED board is on but failure to start.
By elumrich on Nov 11, 2009
Solution #1
posted on Nov 11, 2009
Not Rated)
mbase213
Rank: Guru  ASUS Computer Components  Expert
Rating: 91%, 228 votes
Hi elumrich,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
Was this helpful?
Yes
No
Popular Solutions for ASUS P5P800-VM Motherboard
Questions and Unsolved Problems for ASUS P5P800-VM Motherboard
Do you recommend ASUS P5P800-VM Motherboard?
Answer
Answer
Poler Expree O gauge Train, working all morning..Train goes arou7nd but the throttle is not... (More)
Answer
no video driver present since a reformat and can't seem to download, motherboard is a k8m400 for an... (More)
Answer
I need the manual for motherboard P6V693A/A5-133 by QDI
Answer
driver contoller video
Answer
msr 206x not displaying data whenswiped
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , PA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
