It just means that you need to format a new card in the camera before it will work properly. Go into the menu and find "format"...follow the on-screen instructions.
I've bought a SanDisk ExtremeIII 4GB CFI card. Ofcourse, at the beginig nothing worked. Camera format command worked neither (initializing problem,...). I then formated my card through a car reader on fat16 and now everything works. Just make this command: format <volume>: /FS:FAT. After checking and formathing the card, you will be asked to go on by 64K size of cluster. say Yes.
If your new xD card has an "H" or an "M" before the 1gb, it is not compatible with your camera unless a firmware upgrade is performed (go to www.fujifilm.ca and follow the links for support to the firmware upgrade section). If the card doesn't have the H or M, you just need to format the card in the "set-up" menu of the camera.
If your new card has an "H" or "M" before the 1Gb, your camera is probably not compatable with it unless a firmware upgrade is performed. This can be done by the user, with help and the software download from Fuji' website.
It sounds like your XD card is corrupted. How and why i couldn't tell you. You will need to get the pictures recovered from the card using a special software (image recovery software, can down load for free from some web sites, or some companies can try and do it for you) and then try and format the card in the camera. DO NOT FORMAT THE CARD BEFORE YOU RETRIVE YOUR IMAGES. If you do all traces of the images may be lost.
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
