Question about Philips CDR570 CD Recorder
Dis did not finalize
Hi i had an error and my disk did not finish recording to the end now i cant get it finalize and what caurs that
    Genius:
  • 1,067 Answers
Bad dvd what brand uuseing to burn with philps is touchy are u addingto much to a dvd also i would do mor ethen 4 gb on a dvd 5 disk ok single layer burn it slow does it have a speed adjustment do 4x 8x max
Posted on Jan 07, 2008
I have a H2160MW9A and am recording 1/2 hour segments. When I dub from HDD to DVD I am unable to finalize. I get an error E19 and says disk full. I can still record more 1/2 hour segments to the DVD.
You finalize the disk AFTER you have finished all the recordings on it. Finalizing makes the disk more acceptable (readable) to other players and closes out the disk.
Dec 24, 2016 | Hardware & Accessories
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have a jvc dr-mv150bj. I am knew to recording on DVD. I used the dvd to record the super bowl. I forgot to finalize and I was using a portable LCD projector. I unpluged the dvd recorder and took it...
finalizing completes the process of recording so that the disk can be read to play. Yes, probably if power goes off, you'll loose the recording as the disk can finish.
Basically, the code written at the end of recording creates a sort of index so the player knows how to read it.
May 02, 2017 | JVC DR-MV150B DVD Recorder/VCR
I have had my sony rdr-gx257 dvd recorder for about a year now, never been used. I have been recording gameplay from my ps3 with it since yesterday. I have recorded onto dvd-r disk and dvd+r disk however...
After ending recording, Finalize recorded dvd as option is available in recorder menu.
a Finalized dvd will playback in other dvd players.
Thanks.
Dec 30, 2010 | Sony RDR-GX257 Player
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Finalizing
IF THAT DISC WAS RECORDED ON AND THEN REMOVED BEFORE FINALIZING IT WILL NOT FINALIZE. THE CAMERA LOOSES THE MAIN INFORMATION TABLE FOR THAT RECORDING. ONLY THING TO DO NOW IS, IF THE DISC CAN STILL PLAYBACK ON THE CAMERA THEN CONNECT IT TO A DVD RECORDER VIA THE AV PORT AND RECORD.
Mar 30, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Unreadable disk error
The laser in 5101 could be defective or maybe just dirty.Try cleaning with a commercial cleaning disc,put a drop of rubbing alcohol on cleaning brushes.When this happens sometimes it will still be a usable disc but not always.Try putting in another dvd player or recorder or your PC if it plays dvds,the readers in PC are of a better quality and will often read discs that those cheap dvd readers can't.
R+ or R- discs need to finalized after recording RW+and RW- discs do not.It is always a good policy to finalze the second your recording is finished otherwise it may not play in other players or recorders.
When you make a recording in a dvd recorder an it doensn't recognize the disc it just recorded it quite often has a defective laser.This particular model has been plagued with early laser failure.
Mar 14, 2008 | Lite On LVW-5101 DVD Recorder
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
Philips CDR570 CD Recorder Logo
513 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
