Canon PIXMA iP4000 page of text prints with some (horizontal) lines and sections pale. All ink cartridges are new/full, and I've run utility with perfect results.
de printermodus geeft deze fout aan en vraagt gebruik van handleiding. ik heb deze momenteel niet...
(More)
de printermodus geeft deze fout aan en vraagt gebruik van handleiding. ik heb deze momenteel niet meer in het bezit Dank Cecilia
My printer will print from safari so it's not like it is entirely broken but documents from...
(More)
My printer will print from safari so it's not like it is entirely broken but documents from microsoft word and textedit won't print. I use a MacBook.
Hi I have a canon IP4000 that is about 4 years old and gets a lot of use. Just recently, I seem to...
(More)
Hi I have a canon IP4000 that is about 4 years old and gets a lot of use. Just recently, I seem to be getting many problems with the black ink tank, which when it is down to about 50% full starts missing horizontal lines down the page. i have tried deep cleaning several times but this only clears the problem for 2-3 pages of print. If you remove the cartridge and shake, vigorously until some ink flies all over the room it then starts to work again but he problem comes back when the ink tank is 25% full and I end up having to replace the ink tank again. I only use canon 3e inks, is there a problem with these inks or does my print head need replacing?
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming...
(More)
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
