I installed all new ink cartridges, but the error I get when I try to print is, "unrecognized cartridge" for just the Cyan. Went to Target to replace just the blue one, and they only sell all 4 colors in a pack. Why is this happening, and where can I buy just the blue pack of ink? I tried pulling it out and cleaning the chip on it, and that didn't work. All the cartridges are from the same pack...
I notice that you saw error message 'check ink c'. This means the printer want you to observe cyan ink cartridge. so,what happen before this message appears?. Please make sure that cyan ink is not empty. if you are sure the ink not empty,then remove cyan ink and reinstall it,else try dry clean ink cartridge contact or you may use contact cleaner before reinstall it. if you have have another cyan ink cartridge that is in good condition,compare it. if this works,means cyan ink cartridge is faulty then you need to replace with the new one. but if the problem still persist,it may caused by carriage unit or logic board problem.
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
The following text copied from HP website to tackle this problem.
Follow the instructions below to install the print cartridges.
NOTE:
If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup.
Installing the print cartridges
Verify that the unit is on.
Open the ink cartridge door.
Figure 1: Opening the ink cartridge door
Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
Figure 2: Lifting the latch1 - Ink cartridge latch for the black ink cartridge2 - Ink cartridge latches for the color ink cartridgesNOTE:
The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
Remove the new ink cartridge from its packaging.
Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
NOTE:
Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
Figure 3: Inserting an ink cartridge
Press down on the gray latch until it clicks into place.
Figure 4: Closing the gray latch
Repeat steps 3 through 6 for each ink cartridge that needs to be replaced.
NOTE:
All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
Close the ink cartridge door.
Figure 5: Closing the ink cartridge door
Follow the steps below to remove and replace the empty ink cartridge.
Turn the printer on.
Figure 2: Lifting the latch1 - Ink cartridge latch for the black ink cartridge2 - Ink cartridge latches for the color ink cartridges NOTE:
Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
Pull the ink cartridge toward you out of it's slot to remove it.
Figure 3: Removing an ink cartridge
Remove the new ink cartridge from the packaging.
NOTE:
Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted.
Figure 4: Inserting an ink cartridge
Figure 5: Closing the gray latch
Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
NOTE:
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One Press the On () button to turn off the unit.
Disconnect the power cord from the back of the unit.
Dear all, To fix this problem, first check which ink blinks, then replace it with new one. If this does not fix your problem, here are possibilities: carriage part error, logic board error. Be careful of short circuitry problem in this case. It may harm other electrical part
I have the same issue as well - I just open the printer, pop out the cyan cartridge, and reinsert it (the same one). This generally works - sometimes I need to do it once or twice. I figure I'll be patient and keep doing this until I a) finish the cyan ink cartridge, b) replace it out of annoyance, or c) through the printer out the window in total frustration.
Interesting to hear about "faulty" cartridges though - I shell out for the "authentic" Canon cartridges which you would think would be reliable - maybe I should switch to using the imitation ones if I'm going to have issues with them anyway...?
I too was getting the error for unrecognized ink cartridge. Then the
little green circ board fell out of the end of the ink cartridge and it
hit me that maybe if I put in the little green circ board from the old
ink cartridge of the same color, then maybe the ink cartridge would be
recognized. It worked! So don't throw out an ink cartridge that still
has ink just because of that error and hold onto your empty cartridges
in case you need the little green/gold circ boards.
