Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Picture tube I have a 28 inch Magnavox tv set about 8 years old.When the set is first turned on there is no picture but I have sound. If I tilt the set just a little or hit it lightly the picture will return but not for long. When the set is on for 20 minutes the picture may stay on for over 2 hours or more. All connections in the back are nice and tight. Have any idea whats going on? Don Roberts
  • 579 Answers
It has a bad solder joint. TV's use cheap, one sided circuit boards which don't solder as well and with all the hot and sometimes heavy parts on the board, it is common to have bad solder joints. Especially on the newer ones have have switched to the mandated lead-free type solders. A tech needs to resolder the circuit board using an eagle eye to spy out the bad joint.
Hope Ya Fix it!
Posted on Jan 07, 2008
I have an approxiamtely 8 yr old Magnavox 50 inch DLP t.v and when you turn it on, you can hear it power on but there is no picture. Trying to figure out whether its something that can be repaired and...
I am familiar with this model, if 8 years old do not invest any money in it as most parts are no longer available from Philips.
Saw a lot of them when only a few years old get junked.
May 25, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Jan 20, 2012 | Apex Digital Televison & Video
28-276 Delta bandsaw blade keeps coming off?
Unplug the machine, gain access to the two wheels. On the back of the machine you should have a tilt adjustment knob. Manually turn the wheels in the direction of the cut and at the same turn adjust the tilt knob on the back of the machine. This should solve the problem.
Sep 27, 2010 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
My 50 "Magnavox rear projection has a vary faint picture
If its over 6 years old , sound like the tube are shot , bright/focus together = bad tubes
Jun 30, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture
Can you repeatedly get the picture to come back when you push on the back of the set? If so, yes, its sounds like a bad connection.
What happens when you use the tuner of the TV and with it connected to cable? Do you get a picture?
- Jim
Feb 19, 2008 | Hitachi 35CX45B 35" TV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
