Question about Dryers
Maytag electric dryer model #MDE 4916AYW
My dryer started acting up like it was not getting enough current to tumble over. Now when you press the start button it just makes a noise but now it will not tumble over. What could be the problem?
  • 90 Answers
If your hearing a buzzing noise, motor.. If it sounds like the motor is running, could be a belt.
Posted on Jan 08, 2008
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer MDE 4916AYW: Drum doesn't spin, makes buzzing sound when drying avergae size load works fine if put in small load
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 15, 2010 | Maytag Dryers
Dryer won't heat maytag neptune mde 5500 ayw
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I get the top off maytag dryer, to get inside of it...Model # 6200
The complete Service manual is at the link below. The removal of the top is on page 5-2. Good Luck. Unplug unit before servicing.
Sep 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Need Manual for Maytag Electric Dryer
Go to Maytags website and under support you can usually get an online version of the manual if you know the model # of it.
Jul 26, 2009 | Maytag Dryers
Can't figure out how to get the top off This one looks like a real puzzle. Open the door and look for screws holding the front on, the top seems to lift up once something is released.
Apr 26, 2009 | Maytag Neptune MDE4000 Electric Dryer
Start button only lights up, does not start dryer
I finally fixed it !!!! 1st I replaced both thermal fuses and it still didn't work. So the next day I replaced the timer (start button) and voila !!!! it worked
Dec 14, 2008 | Maytag Atlantis MDE7657BY Electric Dryer
Maytag coin op dryer timer programming for mde-16cs
The maximum run time on this machine's timer is 54 min. There is an adjustable peg on the white plastic index wheel which you can adjust anywhere from 30 to 54 min. For example peg in position E is 30min, D is 36min, C is 42min, B is 48min or for 54 min you have to remove the adjustable peg completely, but don't lose it in case you want to change the time in the future. If it is already in the Max "A" position and shuting off early you might have to change your torsion return spring. Hope this helps
Jan 06, 2008 | Maytag MDE16CS Electric Dryer
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
167 people viewed this question
Top Dryers Experts
