Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson cx5500 it says parts inside your printer are at the end of their service life in the status monitor
  • 6 more comments
  • louierona Mar 10, 2008
    can you please help me get the resetter software?
  • YOYONG Apr 05, 2008
    cx5500
  • Anonymous Aug 01, 2008
    parts inside your printer are at the end of its service life
  • Anonymous Feb 11, 2009
    Hi!!! Gud am… I have desame problem about myepson cx5500…Please HELP me regarding my problem about my cx5500 resetter… Can you plsssreply at once… Hope you can help me.,.. I geuss I can pay for that if you havea software resetter of cx5500… Thanks and more power…
  • Anonymous Mar 05, 2009
  • arjo_benjo Mar 24, 2009
    i reset my printer, and the blinking light is back to normal. means it ready to print. but i see error message "parts inside need replace"
  • Anonymous Apr 30, 2009
    Parts inside your printer are at the end of their service life. See your printer documentation. (Epson CX5500)
  • Renato Javier May 11, 2010
    I have a EPSON CX5500 resetter software that I got from a company that does CISS conversion.
    If you want to discuss, send me an e-mail at [email protected].
    I am from MetroManila, Philippines
    Rene Javier
I need some software for resetting epson cx 5500, please ?
Posted on Sep 26, 2008
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a9
Posted on May 22, 2009
  • Epson Master
  • 1,113 Answers
It needs to have it's waste ink pads replaced to prevent possible spillage. Not such a easy job, entails the entire machine to be disassembled, pads replaced, and it will also require a service reset (I believe that the cx5500 has not as yet had it's service software cracked). To be honest one is better off replacing it.
You would be quoted between Aus$100 to 150 bucks to repair it from a dealer.
Posted on Jan 07, 2008
Actually there's available resetter already. i tried it and it works. Regarding Waste pads, just pull the waste ink hose out of your printer and just do something to hold the waste ink that will squirt out of it..
Posted on Mar 10, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 89 Answers
SOURCE: epson cx5500
See if this works for you:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers. (http://www.ssclg.com/epsone.shtml)
  12. Select your printer and model number, then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done!
Additional troubleshooting…
If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again.
If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Posted on Nov 02, 2008
I changed the cartridges in my epson cx5500 but its still not working
Problem with the Epson Stylus CX5000 InkJet Photo Printer
i changed the cartridges in my epson cx5500 but its still not working
Hi Good day!! is there any error message? or Blinking orange/red in your printer? if no errors try to restart your printer spooler.
Follow this method:
1. Turn off your printer and then trun it back on see your printer status if it is online and ready.
2. Click "Start"
3. Click "Setting"
4. Click "Control Panel"
5. Choose "Performance and Maintenance"
6. Click "Administrative tools"
7. Click "Services" now you should be on Services box
8. in Services box find "Print Spooler" Click it and then click "stop" at the upper left of the box and then start it again.. hope it works now..
Oct 19, 2010 | Epson Stylus CX5000 InkJet Photo Printer
My epson r 230 printer is showing 'service required parts inside the printer are at the end of their service life' please find the solution
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
May 20, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson stylus cx5500 printer problem
probably refers to empty cartridges
everything has a service life and it could be a possible part that is wearing out and needs replacing
you have 2 options --ignore it untl it stops performing
or get in a service technician
Oct 28, 2017 | Epson Stylus 2200 InkJet Photo Printer
It doesnt work anymore
End life mean ink waste pad full. Printer stop to print because for preventing waste ink flow to other part. It must to reset waste ink counter using resetter software. And replacing/washing pad, or just extend outlet pipe form haed cleaning mechanic to outside. What type of your epson printer, I have some resetter for epson.
Mar 18, 2010 | Office Equipment & Supplies
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
Aug 05, 2009 | Epson Stylus C70 InkJet Printer
The status of my printer (epson stylus c45)is idle. There's this yellow exclamation point before the message-Service Required then...inside the dialogue box it's written that Parts inside your printer are...
You will need to get it serviced at an authorized Epson Repair shop as the parts that are at the end of service life are not user servicable. With the price of printers today it would be cheaper to buy a new one with updated technology than to try and have this one refurbished. Hope this helps.
Jul 19, 2009 | Computers & Internet
Epson C67 Printer
well generally the printer is always service-able, and parts that has reached the end of life are sometimes cheap, but OEM parts may be a little expensive.
here is a documentation for c67
http://www.epson.com.ph/epson/manuals/manual_download.htm?dc=1&mode=3&m=false&catid=1&pid=865
http://tech.epson.com.au/downloads/message.asp?platform=vista&techtips=techtips&EmailAdd=&MetricIDReturned=2592679&submit=Search+%3E%3E&sCategory=Inkjet&id=stylusc67
hope this helps out, if you have other questions just lemme know
Oct 22, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus CX1500
epson cx1500 reset porgram:
pop up for epson advises:
Feb 11, 2008 | Epson Stylus CX1500v Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
3,827 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
