Question about Nintendo Wii Console
2nd Wii Remote will only not connect in Link's Crossbow Training
Here's the problem. Whenever, I try to connect my remotes prior to playing Link's Crossbow Training, the 2nd will never connect. It will flash, and seemingly start to connect but then turns back off. It is not the remote, because it will not connect regardless of which one is the second or the first. It connects immediately with every other game and with no games at all, and I've reset the syncs many times, and still nothing works. If I connect them prior to loading the game, they shut off before the game's main screen appears. I played it a few weeks ago with no problems whatsoever. Thank you, any help would be appreciated.
  • 3 Answers
This is a ONE player game. It won't connect because the Wii isn't looking for any additional controllers. It's not a problem.
Posted on Jan 10, 2008
I tried to play links crossbow training and the cross hairs kept jumping around all over the place. i couldent hit anything. what do i do to fix this?
You have to go in your Wii settings menu and then select the sensitivity menu, there you can adjust the sensitivity of the Wiimote as you please.
Mar 31, 2010 | Nintendo Wii Console
2nd wii remote is slow compared to 1st one, especially when bowling. Purchased a 2nd remote so my fiance & I can play against each other. Only problem is that the 2nd remote is "slower". It is quite...
Have you tried adjusting the sensitivity on the Wiimote?
Go into your Wii's System Settings and try to adjust the sensitivity using that Wiimote. This could help.
Nov 28, 2009 | Nintendo Wii Console
My wii remotes aren't working
First unplug the AC adapter from power cord and wait 10 min.Then plug it again and open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Remote and push the red button there.Do the same for second Wii Remote.If this not help press and hold
the red SYNC button on the console for 15 seconds. This will clear all synced Wii Remotes from the console.Then try sync the Remotes again.
Nov 09, 2009 | Nintendo Video Game Consoles & Games
Wii Remote Problems!!
This is factory default with the Nintendo Wii, Try simply removing the batteries when done, OR!, which I do, is hold my hand over the top of the WiiMote and then press the power button, this prevents the Wii from getting the remote's instruction to power down, the remote thinks the Wii got it and then shuts down. Good Luck!
Aug 16, 2009 | Nintendo Wii Console
Trying to connect 2nd remote of wii for mario play
You will have to resync the remote.
1. Press red button in the battery area
2. hit red button on the front of wii
Aug 04, 2009 | Nintendo Wii Console
2nd wii remote & nunchuk won't work
well on the front of the wii where you put the sd card there is a red button next to the slot push that then the red button in the back of the wii remote with the battery cover open. its called syncing the wii remote to the system and it should help ya cheers
Jan 28, 2009 | Nintendo Wii Remote Controller
2nd wii remote wont connect
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Dec 28, 2008 | Nintendo Wii Console
Cursor moves spoardically across screen
# Check that the Wii sensor bar is on or below the centre of the TV,and there is no obstruction with clear line of view between it and the Wiimote
# Go in Wii settings and check there are only 2 dots visible. If yes, crank up the Sensor bar sensitivity to 5 with 2 dots still visible, else adjust it till the 2 dots become stable at whichever sensitivity
# If there are more than 2 dots, there is some IR source in the rooms which is disturbing the wireless connection between the Wiimote and the sensor bar, so that source has to be removed from the room
Nothing else works, then resync the remote. Remove the batteries, wait couple of inutes, reinsert, and resync through the 2 red buttons.
Dec 26, 2008 | Nintendo Wii Console
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
2nd wii remote will not connect with mario play 8
We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
This is from www.nintendo.com/wii :
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Dec 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
134 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
