Error code U3 could mean the drain pump is blocked.
Remove the trays and the impeller arm. Empty the water with small container or towel. Open the filter plate and drain filter. Get the motor out and check the cavity for any rubbish. Also use a stiff thin wire to clean the passage between drain filter and motor cavity. The instructions for removing the filter plate and motor assembly are in the user guide.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Fisher and Paykel 24 in.
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
both draws flashed up Red F1, i got it outside and drained it out and ran a cycle through it, about...
(More)
both draws flashed up Red F1, i got it outside and drained it out and ran a cycle through it, about half way through it the bottom draw stopped and the light went out and then the top draw did exactly the same. now it has no power to both draws. does it have fusses or a breaker switch?
The dishwasher is making a horrible noise. Could it be the motor? Tried running both drawers and...
(More)
The dishwasher is making a horrible noise. Could it be the motor? Tried running both drawers and same noise each time. About how much would it cost to replace motors? Would I be better off getting a new dishwasher?
F Paykel two drawer: first the top drawer would not close because of the plastic bracket in the back...
(More)
F Paykel two drawer: first the top drawer would not close because of the plastic bracket in the back was malrotated...when fixed, it blew a fuse...fuse reset but the top drawer (only) shows no signs of life when start button is pressed
