Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer overflows when draining down the pipe!
Is there a switch or some way to lessen the water coming out to drain?
From experiencing this problem myself and reading other comments, if you are sure there is not a clog somewhere, then reducing the rate at which the water comes out of the washer or getting a pipe with a larger diameter might be the most reasonable solutions.  As for myself, I am going to try reducing the flow from the washer first...
Posted on Jan 26, 2008
    Sergeant:
    Champion:
  • 310 Answers
Your wall pipe needs to be longer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 07, 2008
Our washer drains and overflows... we have had the lines checked and any clogs removed less than 24 hours ago. Doing laundry tonight and it overflowed again. When cleaning up all the water we tipped t
If the drained water is overflowing at the drain in or on the wall, that drain may be too small in diameter for the volume of water being pumped out of the washer. Because it is pumped out, it is generally moving faster than water that would be drained by gravity. ALSO very important is the height of the drain connection. I had that problem and had to extend the drain pipe about a foot vertically. The entry point of the pipe can be too close to the P trap, which slows down the flow as it changes the direction of flow. If there is not sufficient volume above the trap, it can back up and overflow due to slower flow through the trap.
Aug 15, 2014 | Washing Machines
Water flows out of the overflow sometimes
If you are referring to the water coming out of the top of the drain pipe that the washer drain hose hangs in, then you don't washing machine problem. The problem is a "slow drain", which is a partially clogged sewer line. This was a constant call when I used to repair ( and still is according to some of my friends still in the repair field). Snaking out the drain or using a safe drain cleaner down the pipe is the best solution.
Hope this helps
Jan 28, 2011 | Washing Machines
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Drain pipe for washer overflows..how do I clear it out?
if the water is coming up from the drain it means your drain is restricted you either need a plumber or you have to run a plumbers snake down the drain to clean it outl.
May 30, 2009 | LG WM0001HTMA Front Load Washer
Water overflows from drain pipe
2 ins is rather small and there may also be a partial blockage somewhere in the system you are not aware off.
a naughty cure is to restrict the drain hose of the machine so water comes out a bit slower
Sep 05, 2008 | GE WBSR3140DW Top Load Washer
Water overflows drain pipe when draining.
you don't you get a different plumber may only be a partial restriction in drain line and could be any where down the line water is pump out on some washer faster than a restricted drain can handle it and no there is no way to reduce rate water is being pump out..been there have the t-shirt
May 27, 2008 | GE WJSR1070A Top Load Washer
Maytag Washer PAV2300
Was the water coming from the drain line, or the washer? A timer switch wouldn't cause the drain line to overflow. If the timer were defective, the washer would not advance properly, get stuck on a cycle, or not run at all. I may be wrong, but I haven't seen a timer that causes an overflow. The water level is controlled by a pressure switch that shuts the water inlet valves off after the water reaches the reqiuired level. If you click on the link below, I have a posting explaining the minimum requirements for washing machine installations. See if your installation meets these basic requirements.
http://www.fixya.com/support/r389335-basic_washer_installation_tips
The drain line needs to be sufficient enough to allow 17 gallons per minute of water to drain properly. You might still have a slow drain issue somewhere further down the line causing the drain to back up. In addition, if the drain hose was fitting tightly in the standpipe, this tells me that the diameter of the pipe may also be too small. this may also contribute to slow drain problems.
Please read the post and let me know what you decide. I don't think the appliance repairman is in order, maybe a plumber(?). I hope this helps you. Post back if you have further questions/concerns.
May 13, 2008 | Maytag Performa PAV3200
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
61 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
