Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Trigger not working
Trigger will not retract valve. Water just runs out. Little white tip of valve comes out of housing. I the valve all one piece?
Water not realeasing in handtool part of steamvac
Posted on Jan 18, 2008
    President:
  • 1,673 Answers
Sounds like you need to replace the handle valve pieces, if they are available, if not then you will have to replace the hose asm. Just take the valve off and see if one of the pieces have a piece broken off. Then with your model number, you can see if that piece is available from someone that has Hoover parts.
Posted on Jan 10, 2008
I push the trigger and no water comes out
the trigger must made contact to a solenoid valve inside the steamcleaner , open the steamer and measure the solenoid if there is power on , lime could be the problem. open the solenoid and clean the spring and metal piece so it moves again close open normally you can hear it.
Made al safety Always think about your safety, pressure steam, electricity and hot water.
Aug 01, 2016 | Vacuums
My Scooba (brand new battery) won't spray water out to clean the floor. What should I do? I've tried over and over. It moves in circles but no fluid will come out to clean the floor!!!!!
Ive had that problem and what i did was put the tank in the kitchen sink and turned the water on blast and let it everything flush out through the diffeiirent outings in the tank. Also (i think this was the actual solution) i got the little blue squeeze ball thingy and placed the tip over the little white tip (or light blue tip) that lays on top of the unit (you will see it after you remove the tank) and just squeezed and squeezed the ball over and over and over again. Its the same way as you would prime the tank to get the water flowing. I noticed when i did that a tiny white piece of lint came out as welll..so it was probably clogged. but nevertheless, that is alway a must, to prime the machine by placing the tip of that squueze ball over the little nozzle tip thats on top of the unit (which is under the tank itself). )
Aug 28, 2010 | iRobot 5800 Scooba Vacuum
Steam doesn't come out anymore when I pull the trigger. I think the water in the tank is getting hot, but when I pull the trigger, only a little water comes out. No steam
Try putting some white vinegar in the tank to dissolve any hard water deposits. You should use only distilled water in this machine. Don't try to clean anything with the vinegar in it, but take it outside to run the vinegar through.
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from http://www.appliancepartspros.com/. (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Scunci SS 1000
The steps to correct it: The thumb trigger and the sliding brass valve clog up and don't move. So if you use it and press the thumb trigger and no steam comes out, it's probably clogged.
Wait until it cools down. Empty the unit.
1.) unscrew any attachments and you will see where they screw in at the end, two small philips head screws on the end. remove them. The red rounded piece at the end will come off.
2.) now on the top, unscrew the water stopper top where you poor water in.
3.) Now below that is a round rubber piece that surrounds the threaded part where the stopper top screws on to. Grab it with your fingers and lift it up on the sides to remove it.
4.) now underneath here you can see two screws. Remove them.
5.) now grab the whole top piece that is "black" and pull upward to remove it. you may want to start at the front and work it off. It has a few snaps that will release when pulled. I have done this a few times so dont be afraid to pull this piece off.
6.) now you will see the valve assembly. Take a small hammer and tap on the small rounded "brass" nub that is sticking out of the "trigger side" of the valve. To know if it has released, I usually place my lips around the end that the steam comes out of and blow while pressing in on the little brass nub on the other side. I do this until that nub moves freely and I can hear the air escape out the top from my blowing on it. Sounds funny but it works. If not free, tap it harder, a few more times, until it is free. It will free up eventually. It gets stuck from time to time but this will get you back in business fairly quickly.
7.) move the nub a few times to ensure smooth movement.
Re-assembly
1.) The black plastic top will snap into place. Just line up the trigger spring with the red nub and snap the whole black piece back into place.
2.) place the two screws back in.
3.) The rubber protector ring is tricky. You will see the underside has a rubber edge that snaps in place. Work it around as best as possible and i usually use a screw driver to push the last little bit into place.
4.) place the red circular end cap on and the two screws that go with it.
you are all done. Once you do this a few times, you will become a pro OR as the above poster said, use distilled water.
Oct 08, 2008 | Scunci 52000 Handheld Steam Vacuum
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Hoover SteamVac
I'm not sure what your referring too, but Here is how it works. The trigger is snapped into two "rocker retainers" in the handle. when you pull on the trigger, it rocks and pushes on a rod that goes down to another shorter rod and that one pushes on the valve that releases the solution. A common problem was that the "rocker retainers" would break off and the trigger would not push on the first rod so the machine would not release solution. You will have to replace the handle half (called a trigger guard). The trigger itself has two plastic "springs" molded into it. This is all one piece with the trigger and they don't usually break. Also, when you remove and replace the handle, you have to pull the trigger to re-engage the two rods togeather or the machine will constantly spray solution. I hope this helps.
Jan 12, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
216 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
