Dell "Inspiron 2200" PC Notebook
Problem for Dell "Inspiron 2200" PC Notebook
Screen Comes on Pink then soon shuts of
By gsemler2 on Nov 10, 2009
Solution #1
posted on Nov 11, 2009
Not Rated)
fredtmccoyjr
Rank: Wiz  Dell StaffDell Staff Computer Hardware  Expert
Rating: 84%, 95 votes
That is a bad video card. It is time to replace your system board. I am sorry to hear that. I priced replacement boards, and if you get one used (it will have someone elses service tag in it) you can get one for about 140 bucks (not bad, but not great). I suggest you call Dell and see if they have a refurbished board they can sell you, and see if they will have a tech install it. It is likely that they can make an arrangement for you, but, THIS WILL NOT BE FREE. You will have to buy the board, and pay dell for the technician. Your BEST option is head to a computer shop and see if they happen to have any computers just like yours, and you buy the replacement, swap hard drives, and pick up where you left off. If you dont have a pc shop, look for a used 2200 online somewhere. Good luck.
Was this helpful?
Yes
No
Solution #2
Not Rated)
parrotheadpc
Rank: Guru  Dell Computer Hardware  Expert
Rating: 89%, 544 votes
We need to first make sure if we are dealing with a screen failure, cable failure or loose connection. If you have access to an external monitor, boot the laptop up with an external monitor attached and see if you get a normal picture there. If you have access and the picture is normal then we can breathe a sigh of relief that it is not the motherboard and the graphics adapter. The next thing to do is go through the cables and make sure that one is not dislodged from its socket such as the back of the lcd, the left side of the motherboard, check the two wire plug from the lcd inverter to the screen. The inverter which powers the screen may be giving low or reducing voltage causing the screen to dim and fail. Last but not least....the screen is failing and all other components are fine. Below is the factory service manual that will help referencing the removal of certain components.
http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Was this helpful?
Yes
No
Popular Solutions for Dell "Inspiron 2200" PC
Questions and Unsolved Problems for Dell "Inspiron 2200" PC
Do you recommend Dell "Inspiron 2200" PC Notebook?
Answer
Answer
when i turn my laptop on it works as normall then i just get this black screen with no icons in... (More)
Answer
I have this aspire notebook and it is only 2 months old. For some reason, the speakers are very... (More)
Answer
on warhammer 40k dawn of war 2 i put the install code and it says an error i looked everywhere and i... (More)
Answer
Se ha sobrepasado la cacidad del puerto concentrador
Answer
no sound thru hi fifrom headphone sockett
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell "Inspiron 2200" PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
