Crown 3600vz red light above each channel stay on and no out put from amp.
  • travieso2000 Aug 31, 2008
    hello. I have an amp. crown MA 3600vz.any body knows where is the fuse located and how to change it?.
    thanks.
    also the exactly the same question for an amp. yorkville AP6040?
Maybe you should try to check for a HEAT SWITCH or RELAY FUSE or Fuse located inside the amp. the red indicator was telling you that it TRIPED maybe due to SHORTED terminals from speaker or it reached its maximum peak thats why it triped. email me if it worked. im preaty shure it will work. ciao
Posted on Jan 11, 2008
Ineed 3600vz lay-out circut
http://www.eserviceinfo.com/downloadsm/45838/Crown_MA3600VZ.html
Apr 29, 2014 | Crown MA-5002VZ 2-Channel Amplifier
Crown macro tech 3600VZ AMPLIFIER
Haven't found one yet tho i'm wondering... what issue/problem are you having with the amp ?
Robert
Sep 14, 2008 | Crown MA-5002VZ 2-Channel Amplifier
Red fault light on amp high pitch squeal through speakers
Clearly a main power amp failure. Look to the device(s) located on the big heat sink and replace them.
Dec 14, 2013 | Crown CE2000 2-Channel Amplifier
I test my crown amplifier 3600vz a few minites then i stop couse verry hot i discover i open the back panel i saw resistor12 and resitor14 burn,i ask what is the promblem,the value of r12 and r14 is...
The ouput drivers have failed and along with the heavy current drain the resistors burnt off . So before the resistors are changed the entire section of the predriver and output section must be checked before new outputs are installed.
test the amplifier with a series voltage regulator and is there is heavy load drain then shut down and recheck till the drain limit is maintained to confirm the correct working of the amplifier.
Sep 09, 2011 | Crown MA-3600VZ Amplifier
There is a red light shinig inside my CROWN XLS
Lots of electronics have lights (LEDs) that turn on when they are plugged it. Most people just don't notice them. If it is working properly, then the light is normal.
Mar 04, 2010 | Crown XLS 602 2-Channel Amplifier
The power led light just blink they don't stay on
The amp is in "protect" mode. This means that a problem was detected internally and the output section is shutdown to prevent further damage. There are many possible causes of this. Crown amps are not the easiest to diagnose as many use mulitple voltage levels for different amplification stages. I would suggest that you obtain a repair estimate from an authorized Crown service center before proceeding.
Please keep us posted on your progres.
Dan
Oct 14, 2009 | Crown CE4000 2-Channel Amplifier
Fuse for crown ce2000 amp???
The problem is not a fuse. The red light indicates that the unit is in "protect" mode. This means that a problem was detected in the final amplification stage and the unit is prevented from turrning on completely to prevent damaging either the speakers or the amp further. These are not the easiest to repair without prior experience and I would not suggest you attemt the repair. Please seek an authorized Crown repair center for assistance.
Dan
May 07, 2009 | Crown CE2000 2-Channel Amplifier
Crown com-tech 2 channel 400
One channel has failed and is in need of repair. There are some transistors inside that are "noisy" and sending signals down the line. This is a bit tricky to find, but a service shop that does audio repairs should be able to fix this. Figure about $15-$45 for parts depending upon what circuits are effected.
Dan
Aug 29, 2008 | Audio Players & Recorders
Crown IT 4000 from ROMANIA
make cleaning to your filter by air blower------- keep good ventilation around in the pass of air(in-out)----after you finish try to test your amp by connecting one speaker only at a time until you find the bad one--------------if all above did not pass you will have internal problem of hardware and needs service center.
Aug 02, 2008 | Crown MA-5002VZ 2-Channel Amplifier
Crown 3600vz the two red light on amp stay on and does not go off
disconnect your load (speakers) and check.if it is o.k your problem is in speaker.if the problem goen your problem will be short circuit in speaker or cabels.-if not the problem will be in amplifier and this is not logic matter because it is new -anyway try to disconnect all inputs.if the problem goen your problem is in one of the inputs-try to connect input one by one until you find the bad one-if all above failed return your amps back to the shop.(from where you get them)
Jan 02, 2008 | Audio Players & Recorders
134 people viewed this question
 Grubhead
Grubhead
