Riding Mowers and Garden Tractors
Problem for Riding Mowers and Garden Tractors
Generic problem for all Riding Mowers and Garden Tra...
Bought a used Murray wide body 42
By jgrass on Nov 10, 2009
Bought a used Murray wide body 42'' cut 17.5 hp riding mower. One front wheel is leaning outward like the rod should be shorter to pull the wheel in. There is no adjustment. How can I get the wheel alignment correct?
Comments:
Nov 11, 2009
- Neither side has adjustment. Both sides are solid rods from the steering mechanism to the wheel with a small slot on the end that attaches to the wheel. Not like my ATV's that have threads to adjust the tie rod ends. I can loosen the bolt in the small slot & line the wheel up but when I move the mower, the wheel toes out. Crazy.
Nov 12, 2009
- I thought that too but both rods are identical with the identical bend in them. They have the same bend in them as the parts diagram I looked at. I guess my only choice is to replace both rods. Thank you for your help.
Solution #1
posted on Nov 10, 2009
Not Rated)
wireguy212
Rank: Guru
Rating: 88%, 201 votes
There tie rod ends on those rods that can be adjusted,if you see no visible threads than you may need to adjust the other side to match the one tha looks like it is swung out ,maybe it is swung in.
Comments:
Nov 12, 2009
- If there is no adjustment then the rod is bent,replace it or staighten it until the wheels line up.
Was this helpful?
Yes
No
Popular Solutions for Riding Mowers and Garden
Questions and Unsolved Problems for Riding Mowers and Garden
Answer
I want a tractor that bags, is fast (had a GT 3000 and loved it), especially in reverse, and I can... (More)
Answer
I have a John Deere X300 garden tractor. When going into reverse the deck blades stop cutting unless... (More)
Answer
Answer
engine idling high, just need to know how the springs are setup on the throttle control components,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Riding Mowers and Garden...:
Top Riding Mower and Gar... Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Riding Mower and Gar... Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
