Question about Maytag Neptune MAH5500B Front Load Washer
Can't remove detergent holder.
Per recomendation from a Wiz, I unscrewed the top of the despenser and removed it. I can't remove it from the washer. My door is locked and I can't get it open. Possible kinked wire? Help!!!
    Sergeant:
    Champion:
  • 310 Answers
You need to pick your latch key with out breaking it. There is a bolt deep in the center of the tub on most models I dont see the need though
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 07, 2008
Why does my LG top load washer have mold in the detergent area?
This is a common issue, they make cleaning products to remove this gunk. Hot water and bleach will kill it as well.
Feb 01, 2017 | LG Washing Machines
Whirlpool Duet coming up with these error codes FO8 and EO2
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem,
check spring is on lever top of dispenser have to remove top of washer
Dec 26, 2016 | Whirlpool Washing Machines
Where do I insert HE detergent packets into my wirlpool washing machine
The HE detergent packets get thrown into the washer on top of the dirty clothes. Then shut the door and start the machine.
Oct 21, 2016 | Washing Machines
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
How can I access the drain pump on a whirlpool WFW94HEXW washer when there is no lower kick plate? Does the whole front panel have to be removed including the door?
I just took apart my WFW94HEXW2 to clean the pump filter. Here's how: Take off the top panel by first removing the three screws attaching it to the back of the washer. Remove the detergent dispenser by pulling it out while pressing on the indicated tab. Take off the control panel by removing the four screws holding it. Two screws are Torx-20 where the detergent dispenser was. The other two are at the top of each corner and are 1/4 inch hex-head, as are all the others in this procedure. If you're careful you need not detach the wires from the control panel. Just take the wires our of the first two clips so you have enough slack to rest the control panel on top of the washer. Pop out the spring-loaded retaining wire that's holding the door bellows to the front panel. Remove all seven screws from the front panel, three at the top and four at the bottom. Again if you are careful you need not detach the wires to the front panel. Simply lift the panel off the retaining tabs and swing it out like a door with hinges on the right. Keep slack in the wires and securely prop up the front panel. You now have access to the water pump and filter. The filter unscrews so you can clean it and its holder. Reassembly is a matter of reversing the above steps.
Aug 07, 2012 | Whirlpool Duet: WFW94HEXW Laundry : Front...
The soap despenser is broken. looks like the spring is inside the holder and it will not close....stays open at all times. model number for our dish washer is 665.13842k601.Kenmore ultra wash. is this an...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 '';
Aug 01, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    How to install new light bulb
    unlike the older models were there was a small compartment were you could take of a small covering and unscrew / replace the globe they are now a sealed unit if you take the entire top of youl see the globe and black globe holder dont try to unscrew it they dont unscrew if you can order a new globe holder included then simply install as per removal but be carefull microwaves hold a lot of power even when disconnected from power dont touch the capacitor or it will shock you
    good luck
    please rank me ..
    Jul 04, 2010 | Microwave Ovens
    MAYTAG TOP LOAD WASHER MODEL PAVT244AWW, STRING FROM A CURTAIN IS CAUGHT IN THE AGITATOR. HOW DO I REMOVE AGGITATOR TO GET STRING OUT?
    remove the fabric despenser from the top of the agatator, under the despenser is a 1/2 inch bolt, a ratche with a 6 inch extention works well, remove the bolt and the agatator will lift up off the transmission shaft
    Apr 12, 2008 | Washing Machines
    Soap dispenser
    I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
    Sep 03, 2007 | LG WM-2277HW Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    32 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
