Question about Logitech QuickCam Express Web Camera
Mic how do you turn on the microphone while using msn messenger?
  • 589 Answers
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Posted on Jan 08, 2008
I have logitech webcam logitech mic but cannot get the mic to work through windows live webcam works
Typical audio set up
Laptop x webcam/mic x Vista x MSN Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MSN MESSENGER
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jan 10, 2010 | Logitech QuickCam Communicate STX Personal...
Hello, I'm about to buy VX1000 webcam, but I wonder if there will be any conflict with the build-in mic in my laptop (HP, XP Pro SP3) or not. Other makes have dedicated cable with 3,5mm jack to hook the...
Shouldn't be any problem. The VX1000 has a built-in mic and is accessed via the USB connection. When you use applications like MSN Messenger or Yahoo Messenger then you can specify which cam to use (if your laptop has a buit-in one), and also which mIc. So you could if you wanted use the laptop mic and VX1000 cam, or use the mic in the cam.
Sep 17, 2009 | Microsoft LifeCam VX-1000 Webcam
My Microsoft VX-5000 Lifecam Mic Won't Work In Yahoo & MSN?
Normal 0 See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
  1. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
May 15, 2009 | Microsoft Life Cam Vx-5000 Webcam
Hey, webcam problems
Normal 0 Also send this to your family and friends so they have their computer setup properly.
To install Windows Live Messenger, double click on this site to download then install. (http://www.soft32.com/download_30.html )
v
Feb 28, 2009 | Logitech Webcam
Mic on msn wont work
your cam and mic need to set up with the msn
Next go to the Menu Bar on right side, click on Action.
please let me know if this has solved and don't forget to rate
Feb 13, 2009 | Logitech Webcam
Logitech headphones not working with MSN
The internet bandwidth or speed is too low or being occupied by some other programs.Thereby leaving a low speed for the msn to work.The solution would be close some applications using internet or reinstall the msn messenger.
Jan 19, 2009 | Logitech 250 Headset
Does not work on Skype and Messenger
In Vista, right click on the speaker icon in your system tray (usually located at the bottom right of the screen) and select "Recording Devices". Be sure that your microphone is enabled in this list. In Skype and MSN, find the audio hardware setup, and make sure to select your mic-in port into which the mic is plugged.
Dec 12, 2007 | Cyber Acoustics CV-1064 Microphone
Mic not working on MSN Messenger.
i just figured this out!
i've been having the same issue.
(i use vista home edition.)
go to control panel>>hardware+sounds>>manage audio devices.
at the top there are three tabs. click the tab that says audio and click the Logitech audio and set it to default!
Nov 02, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech QuickCam Express Web Camera Logo
141 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
