Question about Nikon SB-28DX TTL Flash
Broken flat ribbon cable on SD 28 flash
During a recent repair of the hot shoe mount, I accidentally snapped the flat ribbon cable from the base to the electronics. Is there a cheap solution to repair the flat wire cable?
Thanks
Hello, after breaking mine this morning I was able to fix the flash so It can fire from the hotshoe.
Any automatic TTL features will still not work however atleast you will be able too fire in auto, and manual modes.
I simply opened the flash by taking off the hotshoe, and then swiveling the flash head 90 degrees to expose the four screws there. You need only remove the two screws from the front side of the unit.
Open the battery door and gently pull away the front case (Be careful there are several delicate ribbon cables that you do not want to snap. From here you can either unscrew all the ribon cables to free yourself room to solder or try and dodge them.
You should now be able to see the rear side of the PC sync socket. There is a blue wire that joins the outer edge of the socket - this is ground. Solder onto this point and join onto the top left circle of the PCB board of the hotshoe. (Opposite corner from where the ribbon cable attatches) There are copper circles exposed on the pcb for easy soldering.
Next, return to the rear of the PC sync socket and note the orange wire coming from the centre pin. Solder a wire to this point, and then down to the hotshoe PCB and to the circle that joins to the centre pin of the hotshoe. (Trace the circuit paths)
Sorry I did this about 30mins ago and I'm remembering this out of my head.
Goodluck
Posted on Jun 04, 2009
  • 667 Answers
I'm afraid not. The ribbon cable (FPC, flexible printed circuit) will need to be replaced. Mending one or two lead on the cable is possible, but not the whole thing. Sorry
Posted on Jan 08, 2008
The foot on the hot shoe mount seems to be broken. I'm sure I can replace the part myself, but where can I find it?
You need to do some work on the web because you did not give us the make and model. Try these links they should get you started.
Konica Minolta Camera Repair Parts
USCamera com distributors of spare parts for digital film and video...
The foot on the hot shoe mount seems to be broken sure can replace the...
Samsung Galaxy Note 4 Rear Facing Camera Lens Cover and Bezel Fixez com
May 29, 2016 | Cameras
Repair a broken hot shoe mount on the speedlight
Have to try tighten down the four screws holding the shoe?
Would you like me to fix it for you?
If it is just the Hotshoe Assy, then you can buy from me.
They come in two versions:
Nissin Di866
Nissin Di866 Mark II
Are you from USA?
Truly,
atdlee@netzero.com
Aug 12, 2014 | Nissin Di866 Digital Flash TTL for Nikon...
Nikon fm manual
A sync cord between the camera and the flash is usually more reliable than the hot shoe. Before getting a cord though try cleaning the contact in the middle of the hot shoe and the contact on the bottom of the flash with an ink pen eraser. They are more aggressive than a pencil eraser but still won't hurt the metal contacts.
Nov 26, 2017 | Vivitar Cameras
How do i change the brake pads?
REMOVAL AND INSTALLATION
  1. Remove disc brake caliper from mounting bracket and support with a length of wire or remove sleeve bolt and rotate caliper up and out of the way to remove shoes. Do not allow caliper to hang by the brake line unsupported.
  2. Remove outboard shoe and lining. Use a suitable tool to disengage shoe springs from holes in caliper housing.
  3. Remove inboard shoe and lining, unsnapping shoe spring from piston.
  4. If installing new shoe and linings, bottom piston in caliper bore using large pliers. Take care not to damage piston or piston boot.
  5. Remove bushings from mounting bolt holes in bracket. To install:
  6. Install new bushings to mounting bolt holes in bracket. Lubricate bushings with silicone grease before installation.
  7. Install inboard shoe and lining by snapping shoe retainer spring into piston. Shoe retainer spring is already staked to the inboard shoe. Shoe must lay flat against piston.
  8. Install outboard shoe and lining by snapping shoe springs into holes in caliper housing. Wear sensor should be at the trailing edge of shoe during forward wheel rotation. Back of shoe must lay flat against caliper.
  9. Install caliper.
  10. Apply approximately 175 lbs. (778 N) of force 3 times to brake pedal to seat linings.
Aug 26, 2010 | 1994 Cadillac DeVille
Tamron 28-300 lens broken off from camera
Hi: The only way to have this lens serviceable is by having a qualified tech repair the lens mount. You can contact the folks at Tamron's service center and ask for an estimate. Good luck: theboyd
Oct 15, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Shoe moung of sb 28
http://www.sdcamerasolution.com/index.php?p=product&id=240&parent=22
Buy it from there and replace it..
May 15, 2008 | Nikon SB-28DX TTL Flash
Connect an external flash and aftermarket bracket
For off camera flash with the C-770 Ultra Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. Please use the following information as a reference: FL-CB05 Shoe Mount TTL Flash Cable - this cable mounts to the Hot Shoe on the C-770 Ultra Zoom; and the opposite end attaches to the aftermarket flash bracket's flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
For off camera flash with the C-750 Ultra Zoom, you will need the appropriate flash cable with your aftermarket flash and bracket. Please use the following information as a reference: FL-CB05 Shoe Mount TTL Flash Cable - this cable mounts to the Hot Shoe on the C-750 Ultra Zoom; and the opposite end attaches to the aftermarket flash bracket's flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
For off camera flash with the C-5060 Wide Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. Please use the following information as a reference: FL-CB05 Shoe Mount TTL Flash Cable (item #200707) - this cable mounts to the Hot Shoe on the C-5060 Wide Zoom; and the opposite end attaches to the aftermarket flash bracket's flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Nikon SB-28DX TTL Flash Logo
1,046 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
