Kenmore 22422 Top Load Washer
Problem for Kenmore 22422 Top Load Washer
My Kenmore Elite is leaking water.It is coming
By rpurser on Nov 10, 2009
My Kenmore Elite is leaking water.It is coming from the bottom of the tub where everything goes into it. It does't start to leak until it starts washing,after filling with water and stops after water drains out.Is this somthing that I can fix or should I call for help. Thanks Bob
Best Solution
posted on Nov 10, 2009
Very Helpful)
oldguy5
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 95%, 121 votes
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenmore 22422 Top Load Washer
Questions and Unsolved Problems for Kenmore 22422 Top Load Washer
Do you recommend Kenmore 22422 Top Load Washer?
Answer
Answer
When I try to start the machine it will not fill with water or agitate it will do the spin cycle. It... (More)
Answer
The top of the spinning post in the middle of the tub now won't spin when washing (evidently... (More)
Answer
I have a Kenmore Elite top loading washing machine. The machine stops in the middle of a cycle and... (More)
Answer
I have a front loader Kenmore Washer and cannot find the Screen Filter. It looks new in front but it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 22422 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
