my friend gave me a router and when i connect it to the modem it won't let me access the router what do i do?
Comments:
Nov 12, 2009
- i was gave a router a linksys wrt54g and when i plug it in the modem and then plug it in to the computer it will not connect to the internet or let me access the router
Nov 12, 2009
- i go to the routers address 192.168.1.1
Nov 12, 2009
- when the router is plugged in it says i'm connected local only so i can't get online it does not ask me for a password and there is no login screen.it just shows that i have a local connection
Nov 12, 2009
- i tryed that and it still didnt let me connect it keeps going back to public.do you have any other ideas?
Nov 12, 2009
- it just keeps saying i'm not online
Nov 13, 2009
- yeah the friend i got it from told me it worked fine for them
Nov 13, 2009
- ive tryed almost everything i can think of when i plug the router intom my modem it goes from private to public when i try to change it it just goes back to public
Nov 14, 2009
- i noticed when i go to ipconfig it says media disconnected does that matter?
Nov 14, 2009
- when i pinged the router it sent and received all packets but it said the device could not be found
When you go to the router, what shows on your computer? Does it give you the login screen, or something else?
Comments:
Nov 12, 2009
- Yes, this happens when your Network is set up as "Public" rather than "Private". I know the names seem backwards, but to go to internet, you must set up your network as "Private". Go into your Network settings and make this small change and you should be good to go.
Nov 12, 2009
- You can make the change by going into Network Discovery and make sure it is set to "on" to have Internet access.
Nov 13, 2009
- Has this router ever worked?
Nov 13, 2009
- Some more info on networks that might be helpful:on gthe topic of home networks:
HUB vs SWITCH vs
A hub is a totally dumb device. If it gets a data signal, it just forwards it to everybody and hopes someone will pick it up.
A switch is just barely smarter. If it gets a data packet, it will try and find the device it goes to, and then send it to that device only, but the device MUST reside on the same subnet. A switch wont send data packets to computers on different subnets
A router is just barely smarter than a switch. It only gets a data packet if the destination computer isn't on the same subnet or LAN. The router then figures out where in the world that computer is located and then sends it in the right direction.
Nov 14, 2009
- I` sure have no more ideas, sorry I couldn't have been more help. Humble apologies.
Nov 14, 2009
- If it pings, sends and receives packets, that says it WAS found, and the "Device Not Found" seems to be a contradiction.
I have a 2006 BMW X3. US spec. I want to activate the daytime running lamps. Is there a way to do...
(More)
I have a 2006 BMW X3. US spec. I want to activate the daytime running lamps. Is there a way to do this without taking it to the dealer?
