Hi, I would be very grateful if you could give me advice on the following :- When i turned on my J.V.C. DR-M1SLB DVD Recorder the STR G6653 Flyback power regulater exploded, blowing half it's face off where the Drain and Source (legs 1&2) are connected. Can you tell me if and where I can purchase a replacement G6653 in Ireland and what other components may be known to contribute to this components failure. Also if this is a common fault with above DVD-Recorder. I look forward to hearing from you at your convenience. Best Wishes, James Pugh.
Dear Sirs, I have the Jvc dr-m1slb recorder and when I record a dvd disc on it, it will not play on...
(More)
Dear Sirs, I have the Jvc dr-m1slb recorder and when I record a dvd disc on it, it will not play on another dvd player. If I finalise the disc, it will then only play the 1st chapter. Can You please advise? Regards Darryl
We had not played the dvd in awhile and when we put a dvd (that had played correctly before) there...
(More)
We had not played the dvd in awhile and when we put a dvd (that had played correctly before) there display read "no disc". Help please!
I repaired the power supply and after rebooting I cannot decode any secam channels only pal channels...
(More)
I repaired the power supply and after rebooting I cannot decode any secam channels only pal channels are viewed through the tuner
