Question about PPI2360 Car Audio Amplifier
Guage of Wire
What guage of wire should i use for these amps
  • Chris29 Jan 09, 2008
    It is going to be ran to a distribution block about 10 feet I guess.
    I will be running 3 amps.
  • 631 Answers
How many amplifiers?
How long is the wire run?
Posted on Jan 07, 2008
  • Perry Babin Jan 09, 2008
    Without knowing the power of the amplifiers, there's no way to tell you what wire to use. Use the 'system power design assistant' calculator on the following page. If you have more questions, let me know.
    Click here
I have 1985 GMC 4/4 it keeps popping fuseable link on fire wall I have checked all the wiring. The red wire that into the fire wall the fuse block show to have direct short when the ignition switch is
I'm not sure which one you are talking about, if I remember correctly there are 2 on the firewall. One is a 16 guage wire which protects all red 12 guage wiring. The other is a 20 guage wire that protects the generator warning light and the field circuitry on the alternator. It will be protecting a 16 guage wire.
Sep 01, 2014 | 1985 GMC K1500
My amp is giving me very little power. what should i do?
There are several things you need to look at.
First, do you have the right guage wire for your amplifier. You need to look at the fuses on the amp. This will give you a good idea what kind of power draw it is putting on the electrical system. If you have one 40 amp fuse, 8 guage should be sufficient, 65 or higher, 4 guage is preferred.
Make sure that your ground is good. Always use the same guage wire as your power wire. If you have a multimeter and know how to use it, it will help find the best place to ground your wire. Always sand around where you mount your ground screw to allow for the best contact of your wire.
Check to make sure your RCA gains are turned up on the amp.
This should give you the best chance of getting good power to your amp, and thus, to your subs. If you still have trouble, there may be internal problems with your amp.
Sep 09, 2011 | Hifonics Car Audio & Video
What makes the bass1500 stay in Protection mode????
Ok, usually a fluctuation in amperage trips the protection on an amplifier. To start, check your ground. This is typically the problem. Use a multimeter to ensure that the ground you have is good. Second is the guage of wire. Look at the fuses on your amp. Add them together and use that as the amp draw total. 50-65 amps from 13 feet to 22 feet run of wire requires a 4 guage. If the draw is larger, you may need larger guage wire. Also, match the ground wire with the power wire in guage.
Happy Hunting
Aug 14, 2011 | Car Audio & Video
My audiopipe amp went into protect mode randomly. even though i have to prevent fuses on my power wire
Ok, for starters you need to clarify if you are saying you have "two" fuses on your power wire. That's what I get from your statement. My question would be why? As long as you place the initial fuse within 12 inches of the battery, you're cool. The purpose is to stop the flow of power in the event of a spike so that your power wire doesn't fry and cause a fire under your vehicle carpet. Second, your amplifier should have fuses that trip when this occurs too. If this has been occuring since you installed the amp, you need to recheck all your wiring (I recommend removing the extra inline fuse). Two things trigger an amps safety mode. 1- an amperage fluctuation or overload. It will sense when there is to high or too low of an amperage flow. Too much fluctuation can damage internal components. 2- Your amp is malfunctioning. If you have an internal short, this could occur. (really it's tied to the first one because it is sensing that the short is allowing a full flow of power at the short, thus causing a fluctuation). Start with the ground wire. Most amperage problems happen because of a poor ground. Think of power like water. If you have a good flow coming in, but poor flow going out, it gets kinda....backed up. This causes a fluctuation of the amperage since the electrons cannot flow properly. Setting off the protection. The other thing to thing about is the correct guage of wire. If you have too small guage wire, the amperage will dip low during heavy usage, causing the other extreme of the fluctuation.
Check what you have. If you are running a load of 50-65 amp (look at the fuses on your amps and add them up), then 4 guage is good from 13-22 feet. If you are running any higher than that, you will need 2 or 0 guage wire. You will also need to make sure to have a fuse slightly higher that the amperage draw you are expecting. As always, make sure your power and ground wire match. I have seen alot of kits made with smaller guage ground wire. They work of the premise that the shorter distance produces less resistance, thus requiring smaller guage wire. I say why risk it. Always use a multimeter when checking for proper ground placement. Also, if you are going to use aluminum or tinned wire (trust me, it's out there), you will need to increase the guage of the wire.
Happy hunting
Aug 14, 2011 | Audiopipe Car Audio & Video
I have a jeep that was converted to a 12 volt system., and a solenoid switch. 1. I have one wire going from the Alt. through the cable to the battery. 2. The battery cable goes to the right side of...
What you have doesn't sound quite right, nor does the advice you are getting, though I don't think it would cause a short either.
I think the right way depends on what you want the amp gage to measure. If you want it to read the total output of the generator, you have to connect everything in the car to the other side (opposite from the generator wire). On the other hand, if you just want it to measure what current is going to the battery, then you put the accessory wires on the same side as the wire from the generator. I have made 2 diagram below. A volt meter is easy, and you can have both, if you like. A voltmeter just goes straight to the battery terminals if you want to know for sure that you are charging. You can use plain ground and the alternator wire, but then if there is a fusible link from there to the battery you are not always sure the voltage is getting to the battery. Does this all make sense?4603398.jpge9d6f29.jpg
Sep 28, 2010 | Jeep CJ Cars & Trucks
Why does My AMp turn off
  You need to use 4 guage or larger wiring with this amp. Also you need to make sure the power wire and ground wire are the same guage.(thickness)
   The ground wire needs to be as short as possible from the amp to the metal of the car.
  Make sure you are using a 14 guage or larger speaker wire form the amp to the speakers.
Jan 15, 2009 | Jl Audio 250/1 Car Audio Amplifier
Installing The Subwoofers to the amp... etc.
You should go with a 4 guage power wire kit. If your amp is going in and out
at high volume than that is your problem. 8 guage will work but, if you want
the proper current which is your power from your battery, going to your amp
than I would recomend the 4 guage amp install kit or just the main power
wire coming from your battery. If you would like contact me and I will send you
to a very good sight with all the info you will ever need for car amplifire installation.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Apr 21, 2008 | Insignia 600W Bridgeable Amplifier with...
Car Audio & Video Logo
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
