Question about TOA Electronics P-924MK2 Amplifier
Connecting input & output on my TOA 900 series amp
Input moduals are U-01 AUX AMP, U-11 AUX AMP, and M-01 MIC AMP. how do i connect to the amp moduals and which do i use? i want to play my BOSE WAVE radio through the amp. What connectors are the output to speakers? I want to hook up a PEAVY SCORPION speaker and two ADS speakers.
  • 682 Answers
Http://www.toaelectronics.com/Manuals/P-906_12_24MK2.pdf.
Posted on Mar 10, 2008
Will the Aux. Input port also work as a earphone system to listen to any audio. This system is in a convertible & this option would be nice going down the road...top down.
aux input is exactly that an input system ( mic , other input device etc)
you need a head phone socket for what you want to do ( output socket)
Jul 05, 2015 | Sony Cdx-gt56ui In Dash Car Cd Player W...
How to connect sony bravia tv to amp
If set has RCA audio outputs, connect the outputs to an input on your amp, say aux, etc. Then set your function control to "AUX" and the audio from your set will be amplified.
Apr 11, 2015 | Sony Audio Players & Recorders
Can u connect a microphone to htr5740 receiver?
only if it has an input for it on the front. check specs from your manual.
there can be another way but it will cost you. a preamp mic plug into one of you inputs via rca connection
Apr 14, 2014 | Yamaha HTR-5740 Receiver
How can i put my technic turntables to my amp and connect amp to my pc
Hi, connect to amp using phono inputs on rear panel. If no phono dedicated inputs you can connect to aux or cd inputs however the volume output from your amp will be low. A preamp will fix that. Connect from the record out plugs on the rear panel panel to the mic input on your computer. You will need a rca to 3.5mm jack cable. Cheers john. Styluscity
Aug 06, 2012 | Technics Audio Players & Recorders
I have a ten year old bose wave/radio/cd player. Sound is great but want to play music from my ipod through the bose. my ipod plays in car using aux cable but this does not have same result when...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jun 17, 2011 | Bose Wave Radio
I have a TOA 301 15W amp and a Bose 151 environmental speaker(40w 4 ohms). I do not have a manual for the amp and wish to connect the speaker as a small PA . My concern is that the output I think I should...
Don't worry about the 7.7 volts. Just connect between COM and 4 ohms and you'll be fine. I didn't find a 301 part number related to a 15w amplifier, but I did find a BG series (115 130) of 15 watt amps manual http://www.toa-products.com/international/download/manual/bg115_mt1e.pdf
Carl
May 08, 2011 | TOA Electronics Audio Players & Recorders
Hi, I have just bought a R-H300 tape deck connected to a CR H250 amp. The play quality is good however I have connected a new mic through the Aux phono ports using a jack/phono converter and the record...
If your mic isn't made for connection to an AUX or Line Level input you won't get its specified performance.
Perhaps if you defined the mic and looked up a user's guide somewhere (retrevo.com comes to mind) you might find what you need to use it. Mic's usually require microphone preamplifiers.
Dec 29, 2010 | Teac Audio Players & Recorders
I want to hook my bose wave up so that I when I play my dvd player and tv the sound goes through the bose
Most Bose Wave players only have one set of input jacks. SO, you have 2 sources (the TV and the DVD) that you want to use. Well, you can plug in the one you want or buy a 2-way switch. You plug both sources into the switch and the output goes to the Bose. You hit AUX on the Bose or remote and you've got it. A local Radio Shack type place should be able to fix you up. Just tell them you need to connect 2 sources to one input - I'm assuming all have what are called RCA connectors on the sources - I know the Bose has them.
Dec 27, 2010 | Audio Players & Recorders
Is there a way that I can play music from my computer windows media center through my bose wave system?
You can obtain a cable that has a 3.5mm stereo plug on one end and two(red, white) RCA plugs on the other end and hook them into an AUX input on the wave radio
Dec 27, 2010 | Bose Wave Radio
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
TOA Electronics P-924MK2 Amplifier Logo
1,498 people viewed this question
Top TOA Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a TOA Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
