It is the condensation from the a/c, the drain for the evap core is stopped up causing the condensation to leak into the vehicle. More than likely you have a bunch of leaves or dirt accumulated in the air box. You can sometimes get compressed air and blow it through the drain hole to un clog it. worst case the air box will need to be removed to un clog it. In the future, to avoid it from getting stopped up, run your a/c on recirculated air to avoid bringing in dirt and debri into the air box.
it is the condensation from the a/c, the drain for the evap core is stopped up causing the condensation to leak into the vehicle. More than likely you have a bunch of leaves or dirt accumulated in the air box. You can sometimes get compressed air and blow it through the drain hole to un clog it. worst case the air box will need to be removed to un clog it. In the future, to avoid it from getting stopped up, run your a/c on recirculated air to avoid bringing in dirt and debri into the air box.
