I have a Kobalt 15 lb. 1 phase 175 psi 1.3 hp, 120v, 15 amp, model 215902 VPK1381509 air compressor that either had no or someone removed, before I got it, the power cord. I cannot find anywhere to connect another one. The on/off pressure switch has only one set of terminals that have the blk and white wire from the motor connected to it. is something missing like a terminal or can I splice the cord in with the pressure switch?
do not connect any powercord directly to your motor wires. if second hand compressor i would get the motor tested first. lead possibly cut off for reason.
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is...
(More)
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
I need diagrahams on setting up a 150 gallon aquarium(glass) no holes in bottem everything has to...
(More)
I need diagrahams on setting up a 150 gallon aquarium(glass) no holes in bottem everything has to come up on left . Have skimmer, wet dry, inline heater , ulerviolet sterilizer , what size of pump and kind should I but and How do I plumb. ?need help Dee
While unseizing a mastercraft 58-7949 compressor my helpful neighbor disassembled the four plate...
(More)
While unseizing a mastercraft 58-7949 compressor my helpful neighbor disassembled the four plate inlet outlet valve. Any pictures of how to assemble one of these properly?
Blows fuse when tring maintain pressure ? Its a craftsmen pro series 150 psi 25gal on 20amp outlet...
(More)
Blows fuse when tring maintain pressure ? Its a craftsmen pro series 150 psi 25gal on 20amp outlet with 10g wire to its own 20amp circuit breaker?
