Question about HP Photosmart C7180 All-In-One InkJet Printer
Putting printer back together
I had a paper jam and opened the back up. I have 3 pieces of the printer that came apart, none are broken. Cannot figure out how to put back together
  • Duke Fan Jan 19, 2008
    I actually already had it repaired, but thanks for this info for the future.
  • 417 Answers
Without seeing them will not know what parts you are trying to describe but if you type in the Google search bar HP parts surfer and then goto that web site, enter a country then search for your model of machine you will be able to look at diagrams of the various parts and locations on screen.
Hope this helps
Thanks J
Posted on Jan 19, 2008
There are pieces of paper jammed inside the printer. I cannot access them by raising the scanner. I could see a small piece but after the ink holder adjusted when I turned the machine back on, the small...
I have mine apart right now trying to fix it. I was able to get my paper jam fixed (had the same problem) by putting another piece of paper through when it tried to roll the jammed paper out.
Does that help?
Aug 13, 2011 | Epson Stylus NX400 InkJet Printer
I have a piece of paper stuck in the top of my hp 1012 printer and I cannot get at the area where the paper is.
Follow these steps to remove jammed paper from the printer
1.Open the print cartridge door, and then remove the print cartridge.
NOTE:  Opening the print cartridge door and removing the print cartridge relieves tension on the product rollers, which prevents damage to the product and makes the removal of jammed pages easier.
Figure 1: Open the print cartridge door and remove the print cartridge
CAUTION:  To prevent damage to the print cartridge, cover it with a sheet of paper to minimize exposure to direct light.
2.With both hands, grasp the paper where it is most visible, including the middle, and then carefully pull the paper straight out of the product.
Figure 2: Remove the jammed paper
3.Look inside the product for any torn pieces of paper or labels, and then remove them.
4.If any jammed paper remains in the input tray or the output tray, grasp it with both hands and gently remove it.
5.Reinstall the print cartridge, and then close the print cartridge door.
Figure 3: Reinstall print cartridge and close print cartridge door
1.Press the Power switch to turn off the product.
2.Wait 30 seconds, and then press the Power switch to turn on the product.
Happy printing.
Regards,
Shrey
Jun 02, 2011 | Office Equipment & Supplies
It always says paper jam and it has no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
if the problem remains, some of the sensor / switches might have become stuck or are out of place, or there is still a small piece of paper or something else inside the machine and its coming up as a paper jam.
The machine would need to be taken apart and cleaned to solve the issue.
Nov 03, 2009 | Dell Photo 964 All-In-One InkJet Printer
I have a paper jam 071-100 and cannot find it. I have no manual and I need help.
alternative :
if the problem remains you will most likely have to take the machine apart to find the paper or unjam one or two of the paper path sensor switches that may have become stuck.
Sep 12, 2009 | Office Equipment & Supplies
Paper jam
try this
alternative :
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Brother 2920 Fax Machine keeps jamming every few pages
Please try this and let me know how it goes
alternative :
Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jams
try this
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Sep 22, 2008 | Canon Pixma iP4500 InkJet Printer
Mysterious paper jam
try this..
alternative :
Oct 05, 2007 | Canon PIXMA MP830 All-In-One InkJet...
I cannot see where the paper jam is
i had the same prob pulled it apart and had to get someone to put it back together ....ha...ha...ha so just get a pro to do it worth the $$$$$$$
Sep 06, 2007 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
