Assuming you have it hooked up to a phone line that is capable of dialing the number you want to fax to, you put your paper in the top tray, dial the number and hit send. The machine will pull through the paper and deposit it under that top tray. You will want to make a copy first so you know you are putting in the paper facing the right direction (it should be face up.) Put a single sheet face up in the top tray and hit copy. If what comes out of the bottom-most tray underneath is an exact copy of your original, then you're fine, if it's blank, then flip the orginal over and try again.
Was this helpful?
Yes
No
Popular Solutions for HP Officejet 5610 All-In-One
the cartridge keeps getting jammed on the left side and when it prints the left side is printing...
(More)
the cartridge keeps getting jammed on the left side and when it prints the left side is printing double. I found a small black rubber piece rectangular shaped but with 2 square corners and rounded on the other half. There is a hole in the middle ,not sure where this fits if it is a stopper or what
