Question about Maytag MMV1153A Microwave Oven
Exhaust fan my mircowave is over my stovetop..theres a fan that pulls "whatever" from the stovetop.. okay at the top of the microwave theres something that looks like vents... my question is when the fan is on does it pull up through the bottom and does it come out of the top... I thought these fans pull up and let out outside??????? I hope you understand my question Thank You proving a point
  • whisp125 Jan 07, 2008
    thank you yes there is a vent in the cupboard above..ahhh it's nice to be right lol
  • 146 Answers
The fan pulls from the range top and either out those vents on top unless there is a vent in your upper cupboard. Then it is vented outside. Hope this helps.
Posted on Jan 07, 2008
Condensation between door glasses
This moisture can accumulate from certain types of cooking (lots of boiling) in the microwave or in extreme cases, from a blocked grease filter or exhaust vent duct.
Spills or large amounts of accumulated moisture should be wiped off. Minor amounts can dry out by themselves easier if you leave the door open after cooking.
Also, when boiling on the stovetop, you should always use the hood vent exhuast fan to keep steam and grease out of the controls and the door area of the microwave. I always recommend using the vent fan with any cooking on the stovetop.
As long as it is not rusting the metal mesh screen or other parts of the door, it can be allowed to dry out over a period of days with the door open.
If it is a convection microwave, using the convection heat will help it dry.
May 19, 2013 | Microwave Ovens
Whirlpool mircowave making grinding noise
The grinding noise could be from the turntable motor, or the fan. Remove plate from oven and put a cup of cold water in, set for 30 seconds and run the microwave, if no grinding is detected it means the turntable motor is near end of life. If there is no change unplug microwave and remove top check the fan mounts tighten if loose, if straps are tight suspect the fan motor.
Jun 11, 2012 | Whirlpool Microwave Ovens
Goldstar mircowave model 1310b parts manuel theres a plate at top of cooking area thats is burned two plastic pins hold it to top of mircowave need replacement, help curtis
Assuming that model is MV-1310B, that would be your stirrer fan cover, part number 3301W2A017A, which you can get from Encompass here or by calling toll-free at 866-779-5835.
If you need new clips / rivets for it, they are part number 4051W3A001A.
Jan 09, 2010 | Goldstar Microwave Ovens
Whenever I open the door on my GE Spacemaker XL mircowave the internal fan goes on. This is the fan that goes on when the unit is cooking and not the exhaust fan. It goes off as soon as the door is closed...
That is normal for it to spin for about a second or so becuase of switch changeover but should not remain on constantly when door is open. Have it checked up if it does not happen like the way I described it.
May 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Feb 02, 2008 | Frigidaire PLMV169DC Microwave Oven
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya:
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: (or the better URL here: Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Maytag MMV1153A Microwave Oven Logo
301 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
