My monitor gets vertical bands of color and then starts to distort. If I use it a few minutes I can...
(More)
My monitor gets vertical bands of color and then starts to distort. If I use it a few minutes I can then go to control panel and change my desktop display and my monitor will come in perfect. When I let it idle 10 to fifteen minutes it will get the bands again. I have bought a new monitor cable hoping this would fix it and it may have helped some. I have also downloaded a couple of drivers but when installing it said I had newer drivers or files than what I was downloading and did I want to overwirte them. I chose not to overwrite them. When I go online on the internet It will clear the monitor up faster. I have AVG for the virus etc protection software. What should I do to get my monitor to work clearly all the time?
i have aopen 19" flat...main connection that goes to computer at rear of monitor is loose and...
(More)
i have aopen 19" flat...main connection that goes to computer at rear of monitor is loose and will not tighten...can i open monitor and fix this?
I have a Viewsonic VX715 The issue with this particular unit is that the picture goes blank few...
(More)
I have a Viewsonic VX715 The issue with this particular unit is that the picture goes blank few seconds after it is turned on. If you turn the lcd off, on, off, on, off, on, off, on. Or change a resolution a few times it eventually starts to work and works properly untill turned off for a certain amount of time. There is not much inside the lcd, only the power board and a signal input board, for a lack of a better name at this moment. The backlight is perfectly fine, picture and backlight are both not operative untill turned on and off a few times. Do I suspect correctly that the powerboard would be the issue in this case, its a single layer board it would not be too difficult to replace any of the components on the powersupply board if required. both inputs have the same issue, does not appear to be a input issue. picture / backlight come on and work perfectly for around 2-5 seconds at first, after which the display goes completely blank but power light remains green. resolution can be changed and the picture will return for a moment with good backlight as well, after a certain amount of on, off, on, off or resolution switching the display operates perfectly for unlimited amount of time untill turned off again after which - being cooled down the on off routine has to be repeated. I've had the display apart a few times now and I can not find anything wrong with the boards.
