Mitsubishi WS-55613 55 in. Rear Projection HDTV Television
Problem for Mitsubishi WS-55613 55 in. Rear Projection HDTV Television
Model ws 55613. LED on the front blinks
By rnrconinc on Nov 10, 2009
Model ws 55613. LED on the front blinks continuosly, TV won't turn on.
Best Solution
posted on Nov 10, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 983 votes
Only two things can cause this:
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver. There are also sites on the internet selling
kits for this repair.
Let me know if you have questions and if this information helped you rate this solution as I do this here for FREE.
SD TECH
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Mitsubishi WS-55613 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55613 55 in.
Do you recommend Mitsubishi WS-55613 55 in. Rear Projection HDTV Television?
Answer
Answer
The video goes blank at random times. Turning the power off and back on then video fine.
Answer
is the mitsubishi ws 55809 DM board compatible with the ww55613?
Answer
I have a Mitsubishi HD 1080 Projection TV that keeps turning off on its own and does not want to... (More)
Answer
i have a mitsubishi ws-55613 projection tv. the overall color looks green and is much darker that it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
