Question about Radio Scanners
Monitor of my SSH-140H broke down
My monitor of my SSH-140A broke down I need help to install a regular computer monitor istead.
0 characters
1 Points
Need instructions on how to program a radio shack pro 649 handheld scanner
1) Press PGM
2) use the UP or DOWN arrow to select a desired channel
3) enter in the frequency you want to monitor - don't forget to include the decimal point!
4) Press ENT
5) repeat from step 2 to enter more frequencies.
Once finished press the SCAN button until "SCAN" is shown on the display.
Dec 23, 2015 | Radio Shack Radio Scanners
My father passed away and we found a Radio Shack Pro -91 Scanner and we no nothing about it . Is there an manual for it
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Nov 29, 2011 | Radio Shack Radio Scanners
Owners manual
Hi, you can get it here .....hope this helps....John
Jul 29, 2010 | Uniden BC246T Handheld Scanner
I need the codes and frequencies for a radio shack digital handheld trucking scanner for a pro-106
Go online and Google your request for this info for your area. If no results, go back to Radio Shack and buy a book that contains all that info for the agencies in your area and/or the country.
Jun 22, 2009 | Radio Scanners
162.550 NOAA weather frequency
Hi and welcome to FixYa,
I am not aware of any computer receiver ported for USB connection capable of 162.550 MHz; almost all are regular FM band. There are however amateur/ham radio equipment that could be interfaced with the PC that covers 136 to 174 Mhz.
If your requirement is to be able to monitor NOAA weather broadcasts, it might be simpler to use Internet Radio/audio streaming. NOAA addresses this particular issue here and here among others.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Radio Shack Pro-94 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Lock out
press manual then scroll though the stored frequencies press the unlock button when you find the number you want, hold down till you get a beep sound. key icon should be displayed and will show that it has unlocked. then resume scanning
Nov 23, 2008 | Radio Shack Pro-95 Handheld Scanner
Yes you can get this part from a radio store, like Radio Shack, and most of these knobs can be installed by hand. So yes this can be fixed.
Jun 25, 2008 | Uniden SC200 Handheld Scanner
Seems to drop off every 3 seconds.
Check if your scanner has been set up to monitor a 'priority channel' whilst scanning. If so then disabling the 'priority' mode will probably stop the regular interruptions that are frustrating you.
Scanners when in priority mode stop what they're doing at regular intervals to check the channel that is set as priority channel to see if it has any activity on it. This is why i think that 'priority' operation fits the issue you are describing.
Hope this helps.
Dec 26, 2007 | Uniden BCD996T Base Scanner
Radio Scanners Logo
22 people viewed this question
Top Radio Scanners Experts
Robert McClure
Are you a Radio Scanner Expert? Answer questions, earn points and help others
