It sounds like it's draging on the motor Also heating up the thermister switch. I would recomend having this look at from a vacuum repair shop ask for free estimates if you call around. save some $$$
My old Hoover Encore makes a buzzing noise when it's turned on with no apparent suction activity. Is...
(More)
My old Hoover Encore makes a buzzing noise when it's turned on with no apparent suction activity. Is it the motor?
i have a Vax VX1, the brush will not work, ive cleaned everything and it moves freely by hand. Is...
(More)
i have a Vax VX1, the brush will not work, ive cleaned everything and it moves freely by hand. Is the switch likely to be the culprit or is it anything to do with the reset button?
I have a Royal RY9200. It blows instead of sucking and the brush is not turning. Taking the bottom...
(More)
I have a Royal RY9200. It blows instead of sucking and the brush is not turning. Taking the bottom cover off found that the belt is not broken therfore is the roller motor that is not working. The motor is not shorted and I think it may not be getting power to the motor. What should I do next? and Is there a maintenance manual that I can get a hold of?
