Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Replace or fix Nikon SB 600 flash
By andrea_skimb on Nov 10, 2009
I have a Nikon Flash SB 600 purchased in 2004. I used it only limited and then in sat in my camera bag for quite awhile. recently when I tried to use it, it won't turn on or power up. I tried new batteries, even double checked that my new camera was compatible with it but nothing worked. Is it worth fixing or should I just replace it?
Best Solution
posted on Nov 11, 2009
Very Helpful)
scarfman
Rank: Master
Rating: 0%, 0 votes
honestly i would just replace it. i am a photographer, and the sad truth is that most pro-sumer equipment costs as much to fix as it does to replace. i am a little surprised you are having this problem. i use some sb 800s that i toss all over the place and haven't had an issue yet. a couple quick thoughts... are the batteries definitely in the right orientation? are the new batteries definitely good? did you press the power button long enough... you often have to hold the power for a few seconds. are the springs in the flash giving you enough tension on the batteries so they are making contact. does this have the optional quick refresh additional battery, is that in correctly? if you have checked those i would look at getting another flash unless you have some kind of extended warranty. =).
Solution #2
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I was able to play with it and discovered the problem was with the lid to the battery case. Once that was tighter it came right to life. Thanks for the help!
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
I have a digitrex ds 3000 camera that i cant seem to get the pictures off the internal memory. I... (More)
Answer
Sony cyber-shot dsc wx1 digital camera
Answer
i have sony cybershot T100.It works fine most of the times.Normally i use auto mode to take... (More)
Answer
I am missing the small part next to the dial mode and between the writst strap hook. With out this... (More)
Answer
My samsung camera cannot take pictures during the day they appear to bright
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
