Flip the laptop over and slide the 2 tabs that are near the carry handle to the unlocked position. This will allow the metal cover on the underside of the laptop to hinge up and be removed.
With the laptop upside down and the carry handle facing you, you should see the battery on the left of the laptop. On the right, there is a silver case about 4 inches long and 2.5 inches wide. This is the hard drive caddy.
To remove /this/ part, carefully push the connecting cable towards the battery until it smoothly disconnects from the hard drive caddy. Remove the caddy from the laptop. Using a small phillips screwdriver, remove the 3 small screws which hold the top of the caddy on. Remove the top, and you will see the hard drive.
As a note - be sure you do not remove the gel lining. This is 99.9% of the hard drive's shock protection. When you remove the hard drive, the cable should come out of the caddy as well. Put the new cable on a new hard drive (HDD must be smaller than 65,536MB), put the new hard drive into the caddy with cable attached, make sure the cable assembly is fitted into the caddy slot, replace the caddy cover, replace the screws, replace the caddy into the laptop. Then, make sure you connect the cable from the laptop PC board to the caddy cable assembly. Replace cover, turn on computer, and set up your Operating System (if needed).
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic Toughbook CF-27 PC
Panasonic Toughbook CF-27 (CF27RJ48AAMC) PC Notebook
Hello out there I just purchased a Panasonic Toughbook CF27 at an auction the Auctioneer said he...
(More)
Hello out there I just purchased a Panasonic Toughbook CF27 at an auction the Auctioneer said he didnt know it if worked I took a chance I pluged it in but cannot find out how to turn it on I see the light that shows its pluged in but nothing comes up on the screan HELP What do I do? Jeff
I dont have a problem w/ the toughbook, i just want to upgrade the motherboard so i can have more...
(More)
I dont have a problem w/ the toughbook, i just want to upgrade the motherboard so i can have more features. Anyone have an idea??
I have a panasonic CF-27EB and am trying to get the USB drive to work I've tried almost everything...
(More)
I have a panasonic CF-27EB and am trying to get the USB drive to work I've tried almost everything less tearing my laptop apart. Any ideas?
Panasonic Toughbook CF-27 PC Notebook? Does any one know of a place to find cdrom caddys for the...
(More)
Panasonic Toughbook CF-27 PC Notebook? Does any one know of a place to find cdrom caddys for the cf-27 can find cdrom drives for good price but with out caddy cdrom packs with caddy are pritty high
the pointer on our workshop toughbook is out by about half a centremeter. how do i get this more...
(More)
the pointer on our workshop toughbook is out by about half a centremeter. how do i get this more accurate as it is annoying my mechanics a lot!
