Question about JVC AV-27F702 27" TV
Will not turn on
Television will not turn on, red timer on front is blinking, I visually inspected the circuit board, but could'nt see any problem, Thanks for your time.
  • 4330 Jan 08, 2008
    Sorry I took your time, I wanted help, not criticism, by the way there is still no visual bad Cap. P.S I do have glasses.
So, you did not find the bad Cap in the powersupply?? Might get yourself some glasses cause you seem to be blind.
Posted on Jan 07, 2008
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
I Have a Sumssung HCL4715W Tv timer flashes 40r 5 times and Tv turns off
A constantly blinking light means shutdown.
The most common issue in this model is convergence-----if the convergence circuit has railed (this means shorted parts) it can cause the set to do what you describe.
Before I suggest a course of action----what is your skill level with electronic repairs? Can you solder and or do a visual inspection?
SD TECH
Oct 28, 2011 | Samsung HCL4715W 47" Rear Projection...
I HAVE THE SONY GRAND WEGA MODEL# KF-50WE620 WHEN I HIT THE POWER BUTTON IT BLINKS GREEN 6 TIMES THEN RED 6 TIMES AND WILL CONTINUE TO BLINK RED 6 TIMES OVER AND OVER
A 6 blink error code on this model is letting you know that your G1 board is not putting out your +17 volt supply. You can inspect that circuit if you are experianced, or just swap out the board.
Apr 01, 2011 | Sony Grand WEGA KF-50WE620 Television
TV has been in storage for a year. Turned it on yesterday and it worked perfectly. Today, when I turn it on with the power button, a red light marked "timer" blinks a couple of times and the TV powers off...
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | Samsung HCL4715W 47" Rear Projection...
Will nt turn on only geet a blinking lite
u may have a bad convergence board , check for bad resistor next to the convergence ic and u will see that they are burn
Apr 23, 2010 | Hitachi 53UWX10B 53" Rear Projection...
MY TV DOESN'T TURN ON....POWER LIGHT BLINKS
power supply board is dead and needs to be replaced. very common problem.
Oct 30, 2009 | Samsung LN-S4051D 40 in. LCD Television
The tv will not turn on by remote or manually.... the small red light on front is just blinking.red.
If the TV fails to power ON, in about 90% of the time is due to a power supply failure. If you intend to DIY, I would suggest to visually inspect the capacitors in the power supply. Replacing them should correct the failure with the TV.
Jul 11, 2009 | Akai LCT2715 27 in. LCD Television
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
No pictures and no sound on Toshiba TW40F80 television
Check soldered-in micro fuses in power supply. Ex.--F851,F852.
If there is a blown fuse, identify which B+ circuit it protects.
Most common - convergence IC's bad===replace.
Need more help? Let me know.....T.
May 21, 2007 | Toshiba TW40F80 40" Rear Projection...
JVC AV-27F702 27" TV Logo
54 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
