Question about Microsoft Xbox 360 Console
Xbox 360 HDMI Audio Analog
I have a Xbox 360 and I connect the unit to my 24" LCD Monitor using the HDMI port. I want to either use the audio but connecting the adaptor back the HDMI cant be used. Is there a slimmer connector that can do just analog or digital audio?
  • 4,402 Answers
Posted on Jan 08, 2008
XBOX 360 HDMI Problem green/purple screen
Try the following:
Reconnect your console and TV:
  1. Remove any devices placed between the console and the TV.
  2. Connect the HDMI cable from the back of your console directly into the HDMI port on your HDTV or monitor.
  3. If you're using an audio-only A/V cable, unplug this cable and then connect the HDMI cable from the back of the console directly into the HDMI port on your HDTV or monitor.Learn more about connecting your console to a TV.
Note If your HDTV has an image-enhancement feature or any kind of digital noise-reduction feature, turn this feature off. See your HDTV user manual for instructions.
Jan 24, 2014 | Microsoft Xbox 360 Console
When I connect my laptop to my tv with an HDMI cable the video works but the sound comes out the laptops speakers. How do I get sound to the tv?
What operating system are you using? If you are using Windows 7, right click on the Volume icon on the system tray and select "Playback Devices". A window would pop up showing you speaker and HDMI. Select HDMI and then choose the "Set Default" Button on top of the OK button. Thats it! If you want the sound to come out of the laptop again when you disconnect the HDMI from your TV, you have to do this again, then choose the speakers.
Mar 01, 2011 | Vizio 42 in. LCD TV
Yes , i have a proview 22 inch monitor and i connect it to my xbox 360 using an hdmi to dvi cable . the only problem is with the sound , it dont work what can i do ??i even try connecting speakers into the...
How do you connect the XBOX audio line out to the monitor audio input? If the xbox HDMI output is set to send the digital audio through the HDMI cable, you will not get the sound since you are using HDMI to DVI because the DVI is not made to accept the digital audio. You will need to to use the XBOX analog audio output instead feeding the audio cable with mini stereo phone plugs, please read XBOX user manual.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | Proview PL926WBi 19" LCD Monitor
Xbox 360-no audio output
You may need to go into your TV settings and turn on HDMI Audio. If this is not enabled (Typically on HDMI 1) The TV will not ask the 360 for Audio and as such won't pull it.
Jun 20, 2009 | Microsoft Xbox 360 Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft:
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works:
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Hdmi in but no analog out
the guy was wrong. the analog and digital portions of the receiver are totally separate.
according to Yamaha:
"Be sure to connect your video components in the same way you connect your video monitor to this unit. For example, if you connect your video monitor to this unit using an HDMI or COMPONENT VIDEO connection, connect your video components to this unit using
the HDMI or COMPONENT VIDEO connection."
sorry bud:-(
Feb 28, 2009 | Yamaha HTR-6130 Receiver
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here.
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
Dec 29, 2008 | Microsoft Xbox 360 Console
PS3 setup to Denon AVR 2807 & Samsung LCD
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
No analog audio output option in the dash board
Are you using a HDTV? If so then just use the HDMI cable.
Jul 01, 2008 | Microsoft Xbox 360 Console
External amplifier connection
I think, maybe the TV you have to have needs an audio out port. wether it's an optical out or an analog out. Provided that you have those ports...just connect it to your amp.
Apr 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,493 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
