Vacuums
Problem for Vacuums
Generic problem for all Vacuums
Brushes in motor are arcing badly and mot...
By fshrgy99 on Nov 10, 2009
brushes in motor are arcing badly and motor only occasionally will start. How do i remove the motor brushes for replacement. (from the green plastic case)
Solution #1
posted on Nov 12, 2009
Not Rated)
vacs_etc
Rank: Wiz
Rating: 76%, 5 votes
This is kinda of tricky. need to know what kinda of vacuum it is first. However if you get it apart. To fix this problem the armeture brass needs to be cleaned & you should replace both carbon brushes. Should be cheap to fix if you are up to it. good luck save some $$$$...
Was this helpful?
Yes
No
Popular Solutions for Vacuums
Questions and Unsolved Problems for Vacuums
Answer
which steam mop to buy
Answer
Can any one tell me how to use a Vax Oasis Carpet washer please?
Answer
should the brushes revolve something got caught on the brushes when vacuuming up
Answer
I have a roomba 560. It's 8 months old. Did not use it for a few months. Now when I start it just... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vacuums:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
