I have a Toshiba DVD-ROM Drive, Model No. SD-M1102 from an old HP Pavilion 8370 w/ Windows 98 that I...
(More)
I have a Toshiba DVD-ROM Drive, Model No. SD-M1102 from an old HP Pavilion 8370 w/ Windows 98 that I let my kids use. The drive won't work anymore and I am not sure what I can replace it with and not spend a bunch a money. Are newer Drives interchangable? Can you help or provide a suggestion? Thanks Ed
drive seems to operate hardware manager says this device is working properly windows xp pro sees the...
(More)
drive seems to operate hardware manager says this device is working properly windows xp pro sees the drive , but never the media i.e. "drive is empty, please insert disc into drive"
Need your resolution to this issue I am facing with my Sony DVD-RW AW-G170A Drive. 1. The drive...
(More)
Need your resolution to this issue I am facing with my Sony DVD-RW AW-G170A Drive. 1. The drive reads and writes CD?s fine. 2. The drive writes DVD?s fine but does not read the contents in windows explorer. The DVD is read using a software called ISOBuster fine. Troubleshooting done: 1. The dvd written on this drive reads fine on another dvd drive on a different system. 2. No upperfilters and lowerfilters seen in regedit. Microsoft fix also run. 3. Ccleaner downloaded and run and junk files and registry entries removed using ccleaner. 4. Nero unistalled. Still nogo. 5. Region code not changed. Only data files (word/excel files) burned on dvd. 6. Tried sony and moserbaer dvd. Same issue on both brands. Writes but does not read dvd only. Please suggest a resolution. Thanks arvind.kakde@gmail.com
