Accurian Won't Turn On...
My Accurian Mp3 Player willn't turn on. It's fully charge and it wont show up as connected to my computer . What shall I do???
  • 2 more comments
  • mskye6 Jan 17, 2008
    My MP3 will not connect to the computer. There is a red light that is flashing. What should I do?
  • Anonymous May 09, 2008
    mi accurian mp3 don't turn on it says that i need to free some space to turn on
  • Anonymous Dec 20, 2008
    mine does the same thing
  • etp93 Mar 03, 2009
    mine wont turn on and it the screen wont turn on when i put it in the usb port of a computer. i dont know what to do.
When I turn on my Accurian MP3 Player, it says connect to PC and go to Device Manager, I dont know where the process is
Posted on May 27, 2008
I just bought a Jensen smpv-2gbub player. How do
How to charge the Jensen MP3 player - Model smpg-v2bub
Ignore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1. When computer is on and at windows screen, attach cable from computer to mp3player with mp3 turned player off. It will immediately show you a connect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3. Now turn the mp3 player on by switching the button on the right side of the device to the on position. It will suddenly show you it's charging - the battery on the front of the mp3 player will have a signal pulsing through it.
4. It will turn off after one minute. It's literally half charged now. Strange I know. Repeat from step 1 and it will fully charged.
If it doesn't fully charge after it turns itself off after 1 minute the 2nd time, then repeat steps from 1, one more time, but this time when it turns itself off after a minute, still leave it connected to the computer for 10 mins even though it looks like it's off. Then disconnect it physically from computer, turn it on with the on button on the right side, press the left side middle button twice and look at the battery on the screen - it should be fully charged now.
Apr 07, 2010 | Jensen Audio Players & Recorders
Jensen SMPV-2GBUB wont turn on or charge
How to get the Jensen mp3 to charge - model smpv-2gbub,
transparent-pixel._v42752373_.gifIgnore instructions that came with it - they don't work.
1.When computer is on and at windows screen, attach cable from computerto mp3player with mp3 turned player off. It will immediately show you aconnect screen on the mp3 player.
3.Now turn the mp3 player on by switching the button on the right side ofthe device to the on position. It will suddenly show you it's charging- the battery on the front of the mp3 player will have a signal pulsingthrough it.
4. It will turn off after one minute. It's literallyhalf charged now. Strange I know. Repeat from step 1 and it will fullycharged.
If it doesn't fully charge after it turns itself offafter 1 minute the 2nd time, then repeat steps from 1, one more time,but this time when it turns itself off after a minute, still leave itconnected to the computer for 10 mins even though it looks like it'soff. Then disconnect it physically from computer, turn it on with theon button on the right side, press the left side middle button twiceand look at the battery on the screen - it should be fully charged now.
Jan 30, 2010 | Jensen Audio Players & Recorders
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Aquabeat wont charge
There might be a problem with the connection. Using the player under water for long periods of time can build a sort of calcium on the connections inside the player. Look to see if the internal connection in green, if so you might want to get a really small screw drive and just scrap some of the calcium.
Jan 09, 2009 | Speedo Aquabeat MP3 Player i
Memory is full
I found the manual and followed the given instructions.
Aug 07, 2008 | Audio Players & Recorders
Accurian 42-198
mine did this also, I charged it and i got to use it one time. after i added a test song it and unplugged it from computer while it was still on, it would not come back on.. somehow i got it to reset, i believe one of the tiny holes near the usb plug is the reset switch , try inserting a safety pin or paper clip and it may turn back on.
May 20, 2008 | Audio Players & Recorders
Accurian mp3
copy it into your itunes library, then sync your ipod. make sure you haven't chosen to manually manage your music!
Dec 27, 2007 | Apple iPod MA446LL/A MP3 Player
My mp3 player frooze
Have you tried resetting the player? get a thin paper clip or something similar and push the tip into the hole. then try charging it again untill fully charged, and remove from PC. Good luck
Mar 27, 2006 | Samsung YP-T8 Digital Media Player
206 people viewed this question
 Grubhead
Grubhead
