Question about RCA F36TF720 36" TV
TV won't turn on
Model number F36TF720
Serial number D165C403T
The tv will not turn on with the remote or with the manual button on the front. I have a surge protector that makes a beeping sound when there is a problem with a short. The noise sounds when I plug in the tv and stops when I unplug it. Do I need to replace the power supply or is it a board some where? Also does this model come with some type of fuse that might need to be replaced? I have been very happy with the tv and do not wish to replace it just yet. Also I would like to get the part numbers so I can order them. My email is debarros.tony@gmail.com. Any assistance is greatly appreciated.
I love people asking questions and answer them at the same time.Seems your surge-protector is smarter than you.
Posted on Jan 07, 2008
I still cannot turn off the fdp lock on my rca 20v500t
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. Try this link for more details.
Sep 26, 2012 | RCA 20V500T 20" TV
How to unlock the television to turn on model 27gt624
Most GE sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Sep 12, 2012 | Televison & Video
How to turn off lock on the tv model 27gt624
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Jun 28, 2012 | Televison & Video
Accidently pressed the FDA button on my RCA TV and now its locked and wont turn on and i dont have a remote to it
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Jun 19, 2012 | RCA Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA Televison & Video
Rca parental lock. Model 20f510td
Hello
Jul 05, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
RCA F36TF720 36" TV Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
