HAVE YOU DONE A VOLTAGE CHECK ON THE ADAPTER? IF NOT, READ WHAT THE VOLTAGE ADAPTER OUTPUT IS. IF THE MEASUREMENT IS DIFFERENT OR DON'T GET A READING AT ALL IT MEANS YOU HAVE AN OPEN CIRCUIT ON THE ADAPTER. MOSTLY MOST WIRES BREAK UNSEEN INSIDE THE PLASTIC INSULATOR NEAR THE PLUG END OR NEAR THE ADAPTER END, WHERE THEY BEND MOST.
Try to configure the 2 routers to work with one another when they are next to each other using standard ;an cable. Once working the powerline should work fine. If you try to configure them when they are apart you have 2 things that could be causing problems to take out the powerline to begin with, then when they are working close, move them apart
Our Powerline devices have security that will prevent anyone from seeing your Powerline network. Using the utility provided with the device, you can encrypt all data transfers over powerline to 56 bit DES. In addition, the range of the powerline signal is limited, in order to help prevent others from accessing the data stream.
While *technically* the Powerline network can function when plugged into a low-end powerstrip, i.e. a powerstrip with a simple fuse, this *seriously* degrades performance, and can block the Powerline network completely.
No. Currently we are only offering Powerline products for the North American market, with support for standard 120 Volt AC, 60 Hz electrical outlets. Simply plugging a 120 > 220 volt adapter will not work, as the transformer will block the broadband signal, not to mention that the increased voltage that is likely to leak through a standard adapter could destroy the product.
While the homeplug 1.0 standard was optimized for homes of around 2000 square feet, our Powerline devices have been tested with excellent results in homes of up to 7,000 square feet.
