I was watching a DVD when an error message came up that said Disc was dirty. I didn't have time to click anything and it shut down. Now when you turn the disc player on it shuts off and you can't get the tray open to clean the disc. Please help
First you need to contact the manufacturer and find out how to do a factory reset if possible. If you have no warranty and reset is not possible. Then remove the metal cover over the top, screws are on back and sides, sometimes top. after you get it open the cd mechanism is wide open. Remove the magnetic lock bearing from the top of the cd spindle. usually 2 screws on the sides. manually remove the cd from the tray and check for any damage, you can clean the lense off with anything softer than cotton, but q tips are a last resort tool. Gently wipe off lens in circular motion, being sure to life the material off the lens toward the edge coming outward. Also. there is a small glass fuse on the other side
of the player, near where the power cord comes out, make sure
that is not blown Replace all parts and leave the screws for the cover out until you are sure it works.
Try to power it on and see what happens. if no luck then get a new super multi blue player, just wait until the price is right but its a great player that supports every type of disc. details at your local electronics dealer
SOURCE: Disc Tray: Daewoo DVDS151 DVD Player
Some have a little hole in the front, you pull the power and use a paper clip. Bend it out so its fairly straight then you poke it into the hole and it unloads the mechanisim. If there is no hole you may have to remove the cover.
SOURCE: sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
SOURCE: dvd player problem
get a dvd cleaner from best buy. mine did the same thing, it would not play any dvds so i resorted to vhs, and once i had watched all of those, i finally got a dvd cleaner and now it works fine
SOURCE: Conia M580 DVD player has
Easy... follow these instructions
Testimonial: "Many many thanks for your help - your instructions were dead-easy to follow and I've now successfully rescued my much-prized "Black Books" DVD disc!!!"
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Hello peter4927,
An, "Error 1305"
message mean that; your computer is unable to read the "Program Disc" properly.
This error can occur if your CD or DVD is damaged, dirty, or caused
by dust.
This can happen, if another program is "preventing your computer
from reading the "Program!"
You will also receive this error if the "Disc Drive"
is damaged or dirty.
Try cleaning the "Disc" first!
"Use a Disc Cleaner, to clean the CD-ROM / DVD Drive.
Place the "Program Disc in the Disk Drive; then "Restart the Computer!"
This will have the CD, or DVD start-up {Automatically}.
Next, you can try to start the "Disc" by using the "Auto-Run."
To do so; place the 'Disc' in the "Disc Drive Tray."
Next, [right click] on the "Computer Icon" to open the 'computer window'.
Now, right click, on the Disc Drive, and select the either, "Open, Explore or {Auto-run}.
Hopefully it will start.
Repeat each action if necessary!
"If there is anything else, you may need help with?
Write a 'comment,' I'll be here to assist you!"
"Best Regards"
disc tray won't open
