Question about Goodman GMS90703BXA Heater
Goodman GMP100-5 Rev Furnace Manual
I am looking for a Goodman GMP100-5 Rev Furnace Manual and Repair Parts manual.
  • Stan Kendrick
    Stan Kendrick Jan 18, 2013
    i have an old electric central heating unit/ it will not heat/can you help me
Hi I have a Goodman Furnace GMP 100-5 with an AC connected to it. How should the wireing be connected to the furnace. It does not work when we turn on the heat. Currently the furnace has a brown wire coming out with 5 wires which is connected to the brown wire from the AC unit. The furnace also has a yellow, white, brown, and green wire hanging out. The thermostate brown wire has 5 wires and the yellow wire is connected to the red wire on the AC wiring and the red wire is connected to the brown furnace red, the green wire is connected to the green wire coming out of the furnace. The other 2 wires white and blue are not connected to anthing.What is the proper way this should be wired?
Posted on Jan 06, 2010
    Sergeant:
  • 288 Answers
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Posted on Jan 07, 2008
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
I have a goodman electric furnace. Model no AR32-1, where can I get a manual. My furnace is making a grinding/squeak noise. Is it okay to run it until it's fixed?
I'm not sure you have a true Electric Furnace or a Heat Pump, since both are electric.
In any event, Goodman has Owners manuals that you can download in a pdf format. Just look for your model #.
http://www.goodmanmfg.com/SearchResults/tabid/37/Default.aspx?Search=Owners+Manual
Feb 04, 2011 | Goodman Heating & Cooling
How do you change the filter on model# GMP075-3?
When looking at the front of the furnace, toward the top, turn the two black tabs so they are vertical, then pull it forward. This will take off the top panel. Now pull the bottom panel up, then toward you. You can now see and change the filter.
Dec 02, 2010 | Goodman GMS90703BXA Heater
I have a Goodman GMP 075-3 Rev B and cannot find the filter to replace it can you tell me where it is
I have the EXACT same problem. Cant find the filter and no manual came wit hthe furnace when I bought hte house!!! AGH!!
Nov 08, 2010 | Goodman GMS90703BXA Heater
Just how do i get an online copy of the following: owner manual Goodman furnace md GMP100-3 I can be reached at Cliffieallen@ATT.net thanks Cliff
Go online and just type in goodman furnace and mdl # any goodman broker will send you a owners manual. I hope it helps good luck
Aug 09, 2010 | Goodman Heating & Cooling
I have a goodman 125-5 rev A furnace and it is showing a three blink error. what is this and can it be easily fixed or do i need to call a furnace tech. to look at it ?
FAN COVER SHOULD HAVE CODE LISTINGS .LOOK AT BOTH COVERS INSIDE AND OUT.  MANY CODES ARE PRINTED SOMEWHERE ON UNIT OR MANUAL. IF YOU TELL ME WHAT IT IS DOING OR NOT DOING I CAN HELP
Apr 19, 2010 | Goodman Heating & Cooling
I need parts explosion for gmp100-5 rev b
If you don't know what it looks like you probably shouldn't mess with it.
Nov 18, 2008 | Goodman GMS90703BXA Heater
Goodman GMPB-75-4 Rev 13
Is there a diagnostic chart either on the reverse side of the blower door or in your owners manual. It may help you to narrow down what is going wrong.
Operate the furnace with the access door off of the furnace and the blower door switch taped on. Watch the furnace and document what happens. Note if the flame starts but goes out in a few seconds and let me know what you experienced.
Nov 17, 2007 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
4,305 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
