White lines & inverted picture at top of CRT TV image
A 10 year old CRT screen has started showing 5 or 6 horizontal white lines in the top 20% of the screen, plus this portion of the screen has an inverted "ghost" image. It isn't consistently there and seems to vary from day to day and from channel to channel - sometimes it is not visible at all on one channel, while being quite pronounced on all the others
  • denice327 Jan 20, 2009
    white lines in top 4 inches of screen with inverted image in white lines.When picture is dark the lines are not there. Toshiba 27a45 manufactured in april 2005.
    Novelist:
    Champion:
  • 211 Answers
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Posted on Jan 07, 2008
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
Aug 03, 2010 | Sansui Televison & Video
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Horizontal lines on top fourth of picture
the guy who sold it to you has the same white lines on his forehead.emagine that. wallmart is real cheap.
Jan 04, 2008 | Sanyo DS32920 32" TV
Poor picture quality
You need to consider the following tips herein as follow:
1) Field collapse (horizontal white line on screen)
R710 dry joints. Same as C2146TN & C2546TN problem solved with thanks to Mike G & Barty. Power off/unplug. Get to circuit board underside with aerial socket up-R710 is near top and right of centre-cluster of 4 joints best resoldered
2) Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Please let me know any update
Nov 29, 2007 | Toshiba 27AF42 27" TV
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
1,620 people viewed this question
Top Televison & Video Experts
