You either have a blown fuse for the siren output or the siren's voice coil is blown. If you are able to open the control panel (they are normally locked) check for fuses on the motherboard (main circuit board) and have them checked. If you have a continuity or meter that measures resistance remove each fuse, check and replace as needed. If the siren's voice coil is blown you will need to replace it with a new one. Some systems use a speaker and some use a siren. Both are different and you will need to determine this first before relpacing.
Was this helpful?
Yes
No
Popular Solutions for GE Security Simon 3 Wireless
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I...
(More)
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I can't figure out how to open the control panel. Thanks a lot for the answer, Mike
