Question about LG WM1814CW Front Load Washer
Ue code
My washer has worked fine for a year or so. now when the load gets to 10 minutes left it beeps and the ue pops up. i tried moving the load around to balance it out and then press start again and it does the same thing.
then i unplugged it and completly started over but selected a different setting to see if it still messed up. it ran until 4 minutes left and still said ue.
please help someone
thanks
    President:
  • 1,294 Answers
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Would be good if you mention which part of the globe u r from.....& rate me if helped. U cld post back for further help.
Posted on Jan 07, 2008
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
An ue code flashing
Hello
UE is an imbalance error which is displayed when either the load is small or the appliance is tilted. You can also check if the washer is balanced and try unplugging the washer for 15 minutes to check if its balanced. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | LG WM-2277HW Front Load Washer
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
Sep 25, 2017 | LG WM2277H Front Load Washer
My LG 2077 stops counting down at 10 minutes and stays there and then shuts off and says UE on every load. Can I replace the timer or is it another issue?
This washing machine is very sensitive to medium to large loads. Try doing a smaller load to see if the error code pops up. UE stans for unmalanced load. Good luck!
Aug 21, 2010 | LG WM-2077C Front Load Washer
Machine keeps getting a ue code. i try to redistribute weight, it starts to spin, then stops again. I removed a sock from the drain at bottom left of machine, but still wont work. what next?
You may have to unplug the washer for a few minutes to reset the control...
Too small of a load will also cause balance problems...
Here is a tip that I wrote about that code...
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
heatman101
Apr 11, 2010 | LG WM-2277HW Front Load Washer
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Keep getting UE code
You have a problem with the ball switch sensor in the back of the unit.  I have seen this problem where the delivery people actually dented the back panel so badly that the ball sensor was jammed up against the tub and kept going into UE error code.  Check to make sure that there is no large dents in the back of the unit.  If everything looks normal, then you will need to call and qualified LG technician to service this problem.
Mar 23, 2008 | LG WM1815CS Front Load Washer
LG WM2077CW (UE error code)
Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
LG WM1814CW Front Load Washer Logo
167 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
