Bunn -o-Matic G3
Problem for Bunn -o-Matic G3 (3 lb. Commercial Coffee Grinder)
It always grinds very fine. I am unable to change
By joe_sipper on Nov 10, 2009
it always grinds very fine. I am unable to change the coarseness of the grin.
Solution #1
posted on Nov 12, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 326 votes
That one is hard to explain but I will try. On the front of the grinder is the adjustment wheel, on the wheel is a small screw, if you put your hand on the wheel it might be about 1/4 inch from the front, back up screw about 1/2 turn or more then make sure the grinder is on 3 or espresso, make sure you can pull out front part of the wheel ONLY. If not back up screw a little more and try again, now that it can move freely without moving the numbers, pull it out and turn it to about 5 or 6 then turn grinder on and very SLOWLY, (This is the dangerous part do not go to fast or you could damage the grinder) turn towards trukish grind when you get close you will hear the burrs slightly touching. Back off the knob a little just before the touching part and turn grinder off. Then pull knob out and turn it to turkish and set screw.
Was this helpful?
Yes
No
Popular Solutions for Bunn -o-Matic G3
Questions and Unsolved Problems for Bunn -o-Matic G3
Do you recommend Bunn -o-Matic G3 (3 lb. Commercial Coffee Grinder)?
Answer
Answer
blade turns very slowly and will not grind coffee beans. Wife, God love her, may have ground nuts... (More)
Answer
calibrate sm 90 coffee grinder burrs
Answer
G3 bunn coffe grinder information regarding reset switch
Answer
I went several computers and can not seem access the users manual link with the instructions: The... (More)
Answer
i have a model B8W and the problem is when i brew a pot of coffee it leaks and thats the only time... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bunn -o-Matic G3:
Top Coffee Grinder Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee Grinder Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
