GE GSL25JFPBS Side by Side Refrigerator
Problem for GE GSL25JFPBS Side by Side Refrigerator
Ice crusher stopped working awhile ago. Today it
By namssus on Nov 10, 2009
Ice crusher stopped working awhile ago. Today it started working again but the water dispenser stopped working?
Any ideas?
Clarification Request
Posted by cmm19987 on Nov 10, 2009
The lines could be clogged. Also check in side of freezer you have a filter and every now and then usually every year you have to replace the filter. It is usually above or near the ice maker. Good Luck
Solution #1
posted on Nov 11, 2009
Not Rated)
rogrrabbit
Rank: Guru
Rating: 90%, 242 votes
replace the water valve write up below Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Was this helpful?
Yes
No
Popular Solutions for GE GSL25JFPBS Side by Side
Questions and Unsolved Problems for GE GSL25JFPBS Side by Side
Do you recommend GE GSL25JFPBS Side by Side Refrigerator?
Answer
Answer
constant freeze up of coils,every 2 weeks,door sealed fine,was told to check defrost coil, was 22... (More)
Answer
The water does not come on when the lever is pressed
Answer
Unit not cooling on either side. Food is defrosting and fridge food is mildly cool.
Answer
How do I change the water filter that is above the top shelf inside the refrigerator? Also, why am I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , OH
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
